Thread: lowering springs
  1. lowering springs
    Aug 2009
    Barnsley
    Hey all
    i've just got my self a set of lowering springs for my Mk 4 golf, im fine with the fitting of the rear springs, but the fronts im a little unsure. looks like the whole hub etc has to come off?
    Does any one know of a good how do guide or just give me a little advice?
    Thanks,
    Dave
  2. Re: lowering springs
    Aug 2009
    Barnsley
    bump
  3. Re: lowering springs
    Oct 2007
    There is no need to remove the complete hub assembly remove the bolt and nut securing wheel bearing housing to the suspension strut.
  4. Re: lowering springs
    Aug 2009
    Barnsley
    Thanks for that, when i've done this is it just a case of knocking the hub down from the strut?
  5. Re: lowering springs
    Oct 2007
    If the right suspension strut is to be removed, additional work is required.Unbolt drive shaft from gearbox flange shaft. otherwise (Both sides) Remove the coupling links from the wishbones and pull the wheel bearing housing downwards off the shock absorber tube.When you remove the bolt insert a spreader in the slot this makes it a bit easier to pull down the housing
  6. Re: lowering springs
    Jan 2010
    telford uk
    Dave
    How have you got on? I have just put some 17's on mine and it looks like it needs to be dropped an inch or so. Can get the parts for about 60 quid but wondering how much labour is involved in fitting them. How many hours do you think, for a decent mechanic?
    Steve
  7. Re: lowering springs
    Aug 2009
    Barnsley
    Hi Steve,
    Mines still on the side lines at min, iv not had the time t get round to doing it my self yet. i asked at a garage too see how much they would charge for labour to fit my springs. they quoted £150 and i wernt willing to pay that. im hoping to get round to it in the next couple of weeks, if the weather decides to stay nice on my days off!!
    Dave
  1. 3.0 Quattro Lowering Springs
    By SHAZA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-04-2020, 10:45 PM
  2. Please Help Lowering springs for 93 Coupe' 2.3?
    By shure in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 16-07-2009, 11:37 PM
  3. Please Help Lowering Springs Advice
    By clarky26 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2009, 03:11 PM
  4. Koni lowering springs error
    By Sunny in forum Golf MK5 - 2004 - 2009
    Last Post: 21-03-2008, 08:56 PM
  5. Lowering Springs
    By mcgowan.b in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-11-2007, 01:41 PM
