Thread: Brake Light - Intermittant Fault
Results 1 to 9 of 9
  1. Brake Light - Intermittant Fault
    Sep 2007
    Hi - I have an intermittant fault with my brake light on my 2002 A4, On a say a 30 min journey the Driver information system will come on about 6 times telling me that the rear left brake light is out. It will then clear itself and be ok for a while. I have checked that when the DIS is diplaying a fault that the brake light isn't working and it's not, The bulb is fine. Any idea's as it's driving me bananas....
  2. Re: Brake Light - Intermittant Fault
    Southern County Softy
    20 Post(s)
    Clean the bulb contacts on both the rear light clusters
    A4 2.5 tdi QS (mapped)
  3. Re: Brake Light - Intermittant Fault
    Sep 2007
    I forgot to mention I have also cleaned the contacts in the light cluster and still have the problem...
  4. Re: Brake Light - Intermittant Fault
    20 Post(s)
    Clean the contacts on both clusters, not just the side where the fault is.
    Change the bulbs, use quality bulbs.
  5. Re: Brake Light - Intermittant Fault
    stchris356 Guest
    replace the bulbs!
  6. Re: Brake Light - Intermittant Fault
    Sep 2007
    Thanks - Didn't think changing to a good make bulb would make a difference...changed to a bosch and job done! Not sure why as the old one hadn't blown but hey ho...
  7. Re: Brake Light - Intermittant Fault
    stchris356 Guest
    Quote Originally Posted by matthewr6097 View Post
    Poor quality + High resistance = Bulb warning light!
  8. Re: Brake Light - Intermittant Fault
    Dec 2008
    Midlands
    Change the bulbs - do both - be careful buying them though as the ones at Halfords are currently packaged up wrong - go to your local Audi dealership and get them, you will need the staggered pin ones
    Audi A4 1.8T Quattro Convertible 200+ BHP
    See it here and let me know what you think! : https://www.vwaudiforum.co.uk/forum/s...ad.php?t=81930
    Youtube Channel: www.youtube.com/555senna
  9. Re: Brake Light - Intermittant Fault
    20 Post(s)
    German car+German bulb= NO BULB OUT WARNING
  1. From a very fed up owner.
    By pistons in forum Fabia
    Last Post: 31-05-2011, 05:19 PM
  2. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. help - problems with my brake lights!
    By katy in forum Golf MK4 - 1999 - 2004
    Last Post: 18-12-2007, 01:01 PM
  5. Brake fault warning light
    By short shift in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-09-2007, 08:16 PM
