Thread: more problems starts and dies
Results 1 to 10 of 11
  1. more problems starts and dies
    south wales
    few days ago i left the ignition on all night in fact it must have been on for over 24 hours :roll:
    when i realised went out to the car no dash lights on dead as a dodo.
    recharged the battery and it started as normal,
    turned it off to finish putting the other bits back together.
    went to restart it and it just cuts out starts for a moment and then dies.
    there's only a partial display showing on the mileage read out and computer display to.
  2. Re: more problems starts and dies
    If you have a spare key try it,there is a fault with the immobilizer but it sounds like something has happened with the dash insert
  3. Re: more problems starts and dies
    Norfolk
    Sounds like immobiliser has lost synch with key. Disconnect battery and try again. If no joy, you will probably need a code read.
  4. Re: more problems starts and dies
    south wales
    ive left the battery disconnected for the last hour just gone out and tried the spare key and it started as normal.
    tried the old key i normally use and its started as normal with that to.
  5. Re: more problems starts and dies
    south wales
    taken the car for a run not been used for a few weeks, but now the air bag light is saying on and the radio is only working on one channel no control over the changer or scan button?
  6. Re: more problems starts and dies
    Norfolk
    Air bag is a "hard" fault which won't erase without a code reset. Did you disturb any wires.
  7. Re: more problems starts and dies
    south wales
    thinking about it the only think i have done is tried to get under the carpet under the passenger seat to dry it out.
    apart from that ive removed the rear seat lower and battery.
  8. Re: more problems starts and dies
    The airbag control light (fault) will probably have been activated by a low battery
  9. Re: more problems starts and dies
    south wales
    ok thanks, any idea,s on the radio/cd player?
  10. Re: more problems starts and dies
    London
    Whoa ! what was that about drying out passenger carpet, where did that come from ?
    I guess you have read about pollen filter blockage -> water ingress in passenger footwell -> water damage to CCU -> = electrical faults ?
    I did have a problem with my fuel pump relay # 372 (p/n 4D0 951 253) which caused my engine to start then die. Once replaced it worked fine.
  1. help a4 estate 1.9 tdi 130 starts then dies
    By foegal-2008 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-11-2009, 10:30 AM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. starts from cold & Dies - BUT
    By robmar0se in forum Leon
    Last Post: 12-04-2008, 06:02 PM
  4. Replies: 2
    Last Post: 07-02-2008, 04:48 PM
  5. Newbie - Polo starts then dies immediately
    By harrassed dad in forum Polo - Derby - Lupo - Fox
    Last Post: 04-01-2008, 12:00 AM
