Thread: Installing front brake pads 2003 Passat 130 TDI
  1. Installing front brake pads 2003 Passat 130 TDI
    I want change the front pads on my 2003 1.9 TDI 130 Passat I have changed pads before on previous vehicles but this seems much more complicated I think due to the ventilated disc can anybody talk me through the process or direct me to a site where I can obtain some advice on installation
    Many Thanks Rob
  2. Re: Installing front brake pads 2003 Passat 130 TDI
    Jun 2006
    UK, Mids
    It's very straightforward, pretty much the same as any other ordinary front discs.
    Make sure you get the correct pads as there are several variations, and remember how the wear sensor wire is routed as it may not be obvious upon reassembly.
    Use Loctite thread-lock on the bolts if not replacing them.
    Pads usually have a self-adhesive coating and the packing paper needs to be peeled before fitting them, some don't come with this so use squeak-stop to stop the breaks squealing.
    http://www.ehow.com/how_5465774_repl...rake-pads.html
    Threadlock
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=250566233995
    Anti-squeal sealant
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=220373832154
    Brake grease for slider pins and pad mounting points
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=360102289393
    I can recommend these people for pads
    http://www.buypartsby.co.uk/
    put in your reg.no. and choose ...
    brake pads - EBC
    EBC Original
    I am pleased with them, especially for the price and made in the UK.
    Audi A8 - 2015 - 3.0TDI
  3. Re: Installing front brake pads 2003 Passat 130 TDI
    Thanks for the info I will give if a go!!!
  4. Re: Installing front brake pads 2003 Passat 130 TDI
    same as any other car , discs play no part in changing the pads. ????
  5. Re: Installing front brake pads 2003 Passat 130 TDI
    n ireland
    Be gentle when retracting the caliper piston. I use a large G clamp and go very slowly. I also take the lid off the master cylinder reservoir. This all helps screwing up the abs unit and master cylinder seals. You can also crack open the bleed screw a little and slowly push in the piston and top up mastercylinder when done.
    You've probably done this by now
    Joe
  1. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. Passat - Change Front Brake Pads
    By csopho in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-05-2008, 04:28 PM
  4. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  5. Fitting front Passat brake pads
    By ansumstan in forum Passat - Archive Topics
    Last Post: 04-12-2006, 12:30 AM
