Thread: Potholes...ESP warning lights
  1. Potholes...ESP warning lights
    May 2006
    South East England
    Could anybody suggest as to why...after unfortunately finding a very large pothole with my nearside front wheel that the ESP warning light would come on? When the light came on i tried the ESP on/off switch with on effect.
    After keying off and restarting the car after my trip to work this morning the light has gone out again and the ESP switch appears to be functioning correctly.
    Just wondered if anybody could suggest a reason why a heavy bump to the front wheel might cause this??
    A6 1.9TDI 130 2002 Saloon
  2. Re: Potholes...ESP warning lights
    May 2006
    South East England
    no takers...? Is it possible this is a problem with the ABS...?
  3. Re: Potholes...ESP warning lights
    Southern County Softy
    20 Post(s)
    If the light has gone out nowyou don't have a problem.
    Could the ABS/ESP have picked up a difference in wheel rotation and flicked the light on.
    Or the bump in the pothole dislodged anABS sensor slightly
    A4 2.5 tdi QS (mapped)
  4. Re: Potholes...ESP warning lights
    May 2006
    South East England
    will check that first...
    The traction control seems to work fine...might have a go at testing the abs on the way home this eve...
    genrally it stays off until i've run few miles then the light appears...
  5. Re: Potholes...ESP warning lights
    May 2007
    sounds like one sensor is struggling to get a reliable signal. Could be as simple as air gap too small, or contamination on the rotor weakening the hall effect.
    plug in VAG-COM, and check fault codes. Should indicate problem.
    If not try a rolling check of the wheel rotation speeds. - need a mate in the car watching readings as you drive in a straight line.
  1. Please Help ESP and ABS Warning Lights on
    By peteo in forum Golf MK5 - 2004 - 2009
    Last Post: 25-09-2009, 06:51 PM
  2. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  3. ESP and WARNING LIGHTS on S4
    By S4MATT in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2008, 02:39 AM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. Passat - ABS & ESP warning lights
    By mtp in forum Archive posts
    Last Post: 07-05-2007, 10:10 AM
