Thread: Trapped Door Wires?
  1. Trapped Door Wires?
    Oct 2009
    Runcorn
    On drivers door recently Ive noticed the elec window plays silly buggers sometimes, Goes down but wont come up, Goes up but wont go down etc until I open door or mess with the wires going into door card. The same applies to radio, When i open the door to get out but with engine running I noticed the door Tweeter speakers cut out, I thought it was a design that cuts the surround when door is open. Again when mess with wires they come back on or cut radio out altogether. The rubber casing around the wiring loom is in perfect condition, No rips or tears, Any advice on how i tackle this? Door card off? Common fault?
  2. Re: Trapped Door Wires?
    Southern County Softy
    20 Post(s)
    Pull back the rubber gaiter and check the loom for broken wires.
    Common problem..
    A4 2.5 tdi QS (mapped)
  3. Re: Trapped Door Wires?
    Oct 2009
    Runcorn
    Done that and loom is also wrapped in black tape, Tricky stuff having just a 5" gap to work in, Looks like its the door card off
  4. Re: Trapped Door Wires?
    Aug 2008
    Somerset
    Before you pull the door card out it's worth trying a good squirt of WD40 into the wiring loom connector (even better if you can pull the connector out of the socket first, though it's a bit of a faff). It could be broken wires but it could also just as easily be a dodgy contact...
    '07 A4 Avant 2.0PD 170 quattro s-line Special Edition and '94 T4 Westfalia California Club 2.4td fettled by ABT
  5. Re: Trapped Door Wires?
    Dec 2007
    no point pulling door card
    you cant get to the wires that way
    u have to unwrap the black tape and tackle the broken wires
    they will look as tho there intact so look close its usaly the brown but maybe 1 or 2 more
    also spraying with wd40 wont cure it
    its a very comon problem and a few threds on it
  6. Re: Trapped Door Wires?
    Aug 2008
    Somerset
    Quote Originally Posted by bez101 View Post
    It will if it's a dodgy contact and not a broken wire. Worked for me, and worth trying before searching for broken wires IMHO
  1. Gravel trapped in front disc brake
    By stonedisc in forum Jetta MK3 - 2005 - 2013
    Last Post: 31-10-2009, 09:32 PM
  2. Question A Trapped Mouse Under The Hood?
    By fancy a cuppa in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-07-2009, 06:50 AM
  3. Another leccy window problem
    By jet in forum Golf MK3 - 1993 - 1999
    Last Post: 09-04-2009, 11:26 AM
  4. '97 A4 ABS coming on with light braking at slow speeds
    By HTinVT in forum Audi A4 - Archive Topics
    Last Post: 03-11-2007, 12:49 AM
  5. T Reg Golf Heater problems
    By johnm in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-11-2006, 11:08 AM
