Thread: Audi A3 Antifreeze
  1. Audi A3 Antifreeze
    I have just checked the strength of the Anti-freeze on my wifes petrol A3, and found that it is low, and has reduced over time.
    The car is 4 years old, and the coolant has never needed topping up.
    Audi say the system is sealed for life, which I dont believe as extended life coolant should be changed every 5 years (Orange)
    Does anyone know the spec for Audi antifreeze please?
  2. Re: Audi A3 Antifreeze
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    I Believe that the G12 ( ++?) coolant does not need changing . However if you renew the water pump at each cambelt change then this question does not really arise with normal mileage motoring. Water pump changes at cambelt change time are not that expensive as most of the stripdown time required for the water pump is already done . Water pumps are not that expensive ( approx £30). I had no coolant problems with a MK4 TDI 110bhp golf over 11 years ownership and 142,000 miles but I did have water pumps replaced with each cambelt change ( 65,000 & 140,000 miles). I think it's foolish not to get the water pump ( & obviously the coolant) done with the cambelt.
  1. New Audi A3 2.0TDI 115g/km
    By onemanparty in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-05-2010, 09:26 AM
  2. The Audi Driver annual awards
    By stuart in forum Chat - Completely Off Topic
    Last Post: 13-12-2009, 07:17 PM
  3. Aluminium a5 coupe prototype shows the lighter side of audi
    Last Post: 04-10-2009, 02:16 PM
  4. New Audi A3 Will Be Free To Charge Into London
    Last Post: 20-08-2007, 08:55 PM
  5. Prime London location for world's largest Audi centre
    Last Post: 23-09-2006, 01:38 PM
