Thread: How was DSG in the snow?
Results 1 to 10 of 11
  1. How was DSG in the snow?
    Apr 2007
    Lancashire
    ...as I'm hoping to persuade the employer to pay for DSG for my next Passat, which I will drive for 4 years.
  2. Re: How was DSG in the snow?
    Manchester, UK
    like an upsidedown toitoise.
    DSG - Doesn't Snow Go
    mine 2.0 TDI (140) DSG PASSAT is completely useless in even the lightest of snow.
    Its fine once you get it moving, however it stays where it is and spins no matter what you do once stopped, any slight covered incline is a turn round and go the other way. I even got overtaken by a double decker bus on a slight hill once - NOT GOOD
    Lowering the tyre pressures seemed to help some (down to 29 psi)
    Tip is to keep it moving and not give it too much gas pedal once you lose traction thatS it, it will slow to a stop and not get ANY grip, even the diesel creep forward on the box span the wheels.
    This is the only thing that i can score this box down on, on every other side it is fantastic
    For the amount of snow we see i would definatley recommend one, paddles are a must, auto hold on the dsg is brilliant.
    GO ON GO ON GO ON - IN A FATHER TED KIND OF WAY.
  3. Re: How was DSG in the snow?
    Dec 2008
    Sale
    I had no problems with mine in the snow, the fact I fitted brand new tyres about 2k miles ago may have something to do with, plus mine has the standard SE 16" wheels not 17s. Certainly no worse than my first Passat that was a manual (the last one was a 4motion so not a fair comparison - shouldn't have got rid of it really)
  4. Re: How was DSG in the snow?
    Nov 2008
    Lincoln, UK
    No problems for me either. I have fairly new Dunlops fitted to the front. Last February it slipped a bit, but the tyres were due change. I let it start to roll using idle only then only use gentle throttle and just about no brakes at all. Certainly, if you gun it, it will slip, but so will any other.
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  5. Unhappy Re: How was DSG in the snow?
    Solihull
    I seem to remember it was pretty lousy in the snow this time last year. Very dificult to get it off the line. If you're waiting at a junction, there is no way you can nip out into a gap. You need to plan well ahead and hope that it starts to move.
    As for this year...I was driving a Golf for three weeks, as my car was back at the garage having its third mechatronic unit fitted! That's the third replacement, so actually its fourth including the original.
  6. Re: How was DSG in the snow?
    Dublin, Ireland
    I had no bother with mine either (2.0 TDI 140). In fact I found it very good .. lost grip maybe twice over the few weeks, and no problems moving off etc - key is to keep it in low gear/RPM till you get moving
  7. Re: How was DSG in the snow?
    Manchester, UK
    Quote Originally Posted by The Fingers View Post
    I should also add that mine is on Mitchelin HP Premacy's which having looked into it are not suitable for use on ice or snow at all, this could have been a big factor when looking at snow performance.
    Main roads are fine, its the uncleared side roads where it was less than useless. During the last few weeks of snow we did get a good 10 inches.
  8. Re: How was DSG in the snow?
    Up North
    The Passat was better than the GTI, both of them DSG and both with good tread depth on the tyres. Delecate driving and a bit of advance planning got me where I needed to be. Because you can't start off in second or third gear the DSG might have a slight disadvantage, but good driving negates it.
    My daughter's Polo, with skinny, half worn tyres peed over both of my cars though. Low profiles ain't ever going to be good in snow.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  9. Re: How was DSG in the snow?
    Sep 2007
    have TDI170, newish tyres on 16 inch rims, drove delicately and didn't seem to have significantly different problems to anyone else driving without winter tyres.
  10. Re: How was DSG in the snow?
    Jul 2008
    Initially had problems but found it brilliant by just sticking it in Sports mode and esp off (who'd figure it)
    Aparently this activates the diff lock in 1st and as it changes down the box at higher revs you actually get something called engine breaking
    Couple the above with just being a lot more gentle with what you do being a taxi driver obviously a lot of stop start on untreated roads I was still working while most of the drivers were getting stuck
  1. Whats Your DSG Like In The Snow?
    By The Fingers in forum Chat - Completely Off Topic
    Last Post: 04-12-2010, 12:37 PM
  2. Europe Ski Trip Snow Chains req
    By Donnaa5dcp in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-01-2010, 08:31 PM
  3. Problem with VAG DSG Gearbox?
    By stuart in forum Chat - Anything with wheels
    Last Post: 21-01-2010, 12:51 AM
  4. Passat DSG stalls when ABS activated in the snow
    By quattrogmbh in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-12-2009, 07:11 AM
  5. Replies: 0
    Last Post: 22-12-2007, 03:29 PM
