Thread: hi all newbie needs advice..
  1. hi all newbie needs advice..
    Dec 2009
    northants
    hi all im a newbie here and could do with some advice..
    purchased a golf gt tdi 115 and bought it cheap with overheating probelms so ive replaced the gasket, radiator, thermostat and now is perfect but have a problem with it starting in the mornings ive fitted new glow plugs and checked the voltage to them and they are fine but still take a bit of cranking before starting ive noticed if you hold the pedal to the floor and try starting it, it seems to start a bit better anyone got any ideas what it could be.... thanks
  2. Re: hi all newbie needs advice..
    Jan 2009
    towcester northants
    get a diag test done
    it could be a temp sensor fault
  3. Re: hi all newbie needs advice..
    Dec 2009
    northants
    ive done a diagnostic on the car comes up no faults and also had a new temp sensor from vw when i did the headgasket?
  4. Re: hi all newbie needs advice..
    Chester-le-Street, United Kingdom
    timing,or the start of a battery failure,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  5. Re: hi all newbie needs advice..
    Dec 2009
    northants
    ive timed it up using the proper timing pegs and the battery is new?????
  6. Re: hi all newbie needs advice..
    Jan 2009
    towcester northants
    where are you in northants?
    i will put vag com on it and check timings etc if you want!
    07711 523638
  1. Question Newbie Buying A4 Advice
    By ghedi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-01-2010, 11:28 PM
  2. Newbie needing advice on A6 purchase
    By Candleman in forum New Member Introductions
    Last Post: 16-10-2009, 08:44 AM
  3. Newbie requires expert advice
    By chocolate in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-09-2009, 09:06 AM
  4. Please Help newbie needing advice
    By gingerjeff in forum Golf MK3 - 1993 - 1999
    Last Post: 20-05-2008, 06:27 PM
  5. newbie looking for buying advice
    By dougalf1 in forum Archive posts
    Last Post: 13-01-2008, 07:29 PM
