Thread: Sharan Parking sensor Problem
Results 1 to 10 of 12
  1. Sharan Parking sensor Problem
    Apr 2009
    The washer hose joint came away on my 04 Sharan there was 2 inch of water in the passenger footwell and my parking sensors did not work no power at all I took the pdc out and dryed it I thought I may get some power back even if it was the orange light on the dash button but nothing I have looked for a fuse but can't find one does anyone know if the system is protected by fuse I don't want to purchase a new unit if it is just a fuse
  2. Re: Sharan Parking sensor Problem
    May 2008
    wirral
    check the relays that are under the pass seat where it was flooded...
  3. Re: Sharan Parking sensor Problem
    Apr 2009
    I didnt know there where any relays under there will check them out thanks
  4. Re: Sharan Parking sensor Problem
    Apr 2009
    checked under the seat could not find any relays
  5. Re: Sharan Parking sensor Problem
    May 2008
    wirral
    if not there you have a fuse board behind your fuse board murder to get to or have a look on www.fordgalaxy.org.uk/ford youll have to register & do a search on there its also in the q&a section & it may even have pictures,sorry i couldnt help any more...alls i can say the start of your problems are under the pass seat footwell when it fills up..
  6. Re: Sharan Parking sensor Problem
    solihull
    Hi, my sensors did work when i bought my car an 04 sharan,but then started playing up and eventually not working,i had no water engress in the footwell but have been told this is a common problem with the parking sensors. I changed the module which cost £100 and this rectified the problem for a couple of days and then the problem came back,are there relays to the side of the pdc module,any views would be most welcomed.
  7. Re: Sharan Parking sensor Problem
    May 2008
    wirral
    do they work at all or do you select say reverse and just get a constant beep and light flash on console...
  8. Re: Sharan Parking sensor Problem
    solihull
    They sometimes work but mostly not but the switch does flash.Found it strange but they always work if i am parked underground in a car park,but not always when outside.
  9. Re: Sharan Parking sensor Problem
    May 2008
    wirral
    it might just be a faulty sensor,to check if one is faulty put it in reverse with just the ignition on dont start the bus then go to the back of car get on your hands & knees and listen to each sensor you will hear a little very low ticking noise,then crawl to each of them and you may find there is one that doesnt make a noise that is the culprit when it happened on my last one when i took it out there was no slack on the cable so it was getting dragged when you leaned on the back bumper to load the boot i just had to replace the one lucky enough but i got mine from a scrapy so i got 3 for £10.failing that it could just be dirt on the connection so may need to clean them all...or may be a dodgy switch you could always get it put on a machine but get on your hands & knees first...
  10. Re: Sharan Parking sensor Problem
    solihull
    Thanks for the reply drodders will try it out tomorrow,would it be the same for the fronts too. You would of thought if a sensor went down the others would still work though or are they wired in series that would explain them not working.Will let you know the outcome,thanks again.
  1. Replies: 1
    Last Post: 14-12-2009, 11:49 AM
  2. Please Help Legal advice, please. (Parking tickets).
    By the surfer in forum Chat - Completely Off Topic
    Last Post: 03-12-2009, 10:58 PM
  3. VW Sharan Parking Sensor
    By Wolverine77 in forum Touran - Sharan - Caravelle
    Last Post: 20-08-2009, 11:52 AM
  4. Parking Sensors For Vw Sharan
    By norie in forum Archive posts
    Last Post: 21-05-2007, 11:41 AM
  5. New model Sharan in 2007?
    By ts58 in forum Touran - Sharan - Caravelle
    Last Post: 15-03-2007, 12:48 AM
