Thread: Audi A4 Flywheel smahes through the Gearbox... Any advice??
Results 1 to 10 of 14
  1. Audi A4 Flywheel smashes through the Gearbox... Any advice??
    Jan 2010
    Bishops Stortford
    I am in a bit of a Pickle
    My 2006 Audi A4 Cabriolet 2.0 TDI S Line seems to have had the flywheel disintegrate and smash through the bell housing of the gearbox.
    I have not had the full report from Audi but I am expecting the worst.
    The car was brought from Audi from new, done 60k miles and is still on finance and has always been serviced by the main dealer.
    Although the warrenty in out by 9 months I am thinking this is an extraordinary situation.
    I wondered if there are any experts out there that can give me some feedback on what I can do and expect.
    Cheers...
  2. Re: Audi A4 Flywheel smahes through the Gearbox... Any advice??
    Southern County Softy
    20 Post(s)
    The dual mass flywheel has fell apart....
    A4 2.5 tdi QS (mapped)
  3. Re: Audi A4 Flywheel smahes through the Gearbox... Any advice??
    Jan 2010
    Bishops Stortford
    Thanks for the reply... I done some research and it seems to be the case.
    I need to find out more about this part and whether it is faulty (although I am sure they are not designed to disintigrate into pieces) if I am to claim from the dealer.
    Anyone else had the same problem?
  4. Re: Audi A4 Flywheel smahes through the Gearbox... Any advice??
    20 Post(s)
    I bet thay wriggle out of any claim you try to make....
    They will blame driving style or any other excuse they can think of..........
  5. Re: Audi A4 Flywheel smahes through the Gearbox... Any advice??
    Jan 2010
    Bishops Stortford
    They probably will, but I read up on consumer law and it seems that under the Sale of Goods act 1979 they have a responsibility for supplying faulty goods for up to 6 years... its worth a go for a Ł4000+ replacement gearbox!
    Also I recall reporting a clutch judder when pulling off, to the dealer on one of the services, which I now hear has a link to the failure of the flywheel.
    Could have been avoided!!!!
  6. Re: Audi A4 Flywheel smahes through the Gearbox... Any advice??
    Quote Originally Posted by PicklePeck View Post
    hehe, I admire your guts, but you'll get nowhere with that argument.
    The vehicle's been running and had fair use since it was bought 4 years ago, IE not faulty.
    the SOG act takes into account fair use and wear and tear....
    I would consider using the argument of full dealer service history and you being the only owner, with only 60k miles and state the noise was reported to the dealer. You can suggest they help to reduce the bill by perhaps forgoing some of the labour charge.
    If you go in all guns ablazing shouting the odds in regards to consumer law that doesn't apply in this instance, they'll shut shop and quite rightly too imho.
  7. Re: Audi A4 Flywheel smahes through the Gearbox... Any advice??
    Jan 2010
    Bishops Stortford
    Quote Originally Posted by Eshrules View Post
    Thanks for the advise, having a bill for Ł4k will get your blood boiling, I think going in with a polite and reasonable request is best
    But getting back to the flywheel, can it not be argued that the design of the flywheel is at fault therefore (not fit for purpose) or (of satisfactory quality) if there are a number of other people out there that have had the same problem is this not evidence of a less than addiquate part.
    Also, Audi as a manuacturer they must give a life expectancy of a part with fair wear and tear, I wonder if they can give some indication to life expectancy.
    The other matter is the associated damage cause by this reletive part which has has penetrated the bell housing and seems like it requires a new Gearbox.
    Is this what you would expect to happen with fair wear and tear or have I got it wrong
  8. Re: Audi A4 Flywheel smahes through the Gearbox... Any advice??
    You don't need to tell me how easy it is to get wound up, I've been there myself bud manners get you everywhere.
    regards the design fault... you can't argue that I'm afraid, because you would be questioning the design of an intrinsic part that's fitted to many engines/cars across the VAG range, flywheel failures are common, but due to wear, not because they're a poor design.
    It's unusual for the bell housing to be affected by a failure though, I'm not familiar with the design so I can't advise in specific relation, but owning a car is hit or miss and sadly you've had a miss.
    I would get a letter sent off, laying out the situation and ask Audi for their response, once you've got that, take it from there.
    Some of the techies may be able to assist further in relation to the specifics, I'm not entirely sure the Ł4000 figure is correct either.
  9. Re: Audi A4 Flywheel smahes through the Gearbox... Any advice??
    Jan 2010
    Bishops Stortford
    Thanks Eshrules,
    Do flywheels usually disintegrate under normal wear and tear? And do you know if Audi accept that they are designed to shatter under normal circumstances?
    Thanks for your advice
  10. Re: Audi A4 Flywheel smahes through the Gearbox... Any advice??
    Jan 2010
    Bishops Stortford
    PS
    By the way I have had a nightmare with cars, all bought from new and just as they leave the 3 year warranty...
    Merc ml 270... new engine rebuild 3.6 years old cost- Ł2500 - 6 months out of warranty
    Freelander... New engine rebuild (faulty oil light sensor) cost - Ł1800 8 months out of warranty.
    Makes London transport look cheap. Oh and dont buy a car off me either.
  1. LONG Product Review/Comparison: Prorack Whispbar (roof rack cross bars + feet)
    By BMWBig6 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-12-2009, 10:11 PM
  2. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  3. World Debut For The All New Audi A3 Cabriolet
    Last Post: 01-12-2007, 06:56 PM
  4. Uk Specification Audi A4 Launched In Frankfurt
    Last Post: 16-09-2007, 09:25 PM
  5. World's largest Audi centre opens on a high note
    Last Post: 29-11-2004, 08:51 PM
