Thread: alhambra 1998 key re-synchronizing
  1. alhambra 1998 key re-synchronizing
    Jan 2010
    corby,uk
    i need to re-synchronize my key but the manual dosn't help very much can anyone help
  2. Re: alhambra 1998 key re-synchronizing
    Oct 2007
    If the vehicle has electric windows, synchronisation is only possible when the windows are closed.
    – Insert key into door lock and turn key three times upwards (unlocking direction).
    – The key must be held in the unlock state for 0.5 seconds within any 5 second period.
    – Remove key from door lock, push and hold down lock button on key.
    – Press unlock button twice and then release lock button.
    The send LED on the key flashes five times for verification.
    The control light in the door trim of the driver's door responds to the initialisation code of the control unit by flashing five times itself.
    The key has been reconfigured
  3. Re: alhambra 1998 key re-synchronizing
    Jan 2010
    corby,uk
    ive now changed the battery's in the key and that now flashes 5 times but the trim light stays solid red ..any suggestions?
  4. Re: alhambra 1998 key re-synchronizing
    Oct 2007
    Do you have the ignition on ?
  5. Re: alhambra 1998 key re-synchronizing
    Jan 2010
    corby,uk
    no . i only have the one key and that one was in the door lol
  6. Re: alhambra 1998 key re-synchronizing
    Oct 2007
    I think that is the problem then,from what i recall the ignition must be on
    This procedure is a bit different but you can try
    If the vehicle is equipped with electric windows then the windows must be closed for the synchronizing sequence.
    ‒ Insert key in door lock and turn forwards 3 times (to unlock).
    ‒ The key must be held for 0.5 seconds in unlock position each time.
    ‒ Remove key from door lock, press and hold key lock button and point key in direction of interior mirror within 5 seconds.
    ‒ For checking procedure, the warning lamp lights up in driver's door trim panel.
    ‒ Press unlock button 3 times then release lock button.
    ‒ The key is recoded. For checking, the warning lamp flashes in driver's door trim panel.
  1. Problem with Advanced Key & One-Touch Memory
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 29-11-2013, 09:51 AM
  2. Key coding problem.
    By njonesn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-01-2010, 08:52 PM
  3. Had my key stolen, help needed urgently - panic over, key found - Phew
    By Mega Maniac in forum Chat - Anything with wheels
    Last Post: 03-07-2009, 07:56 PM
  4. Please Help Central locking works fine but remote doesn't
    By john_richter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2009, 02:46 PM
  5. Vag com. key recoding and Cabriolet SE 1998
    By mariag in forum Golf MK3 - 1993 - 1999
    Last Post: 22-02-2008, 05:54 PM
