Thread: Wheel Bearing
Results 1 to 10 of 10
  1. Wheel Bearing
    Feb 2009
    It can't seem to get a clear answer from the forums - Does the front nearside wheel bearing on a B6 A4 Avant require any special tools to remove, like a press?
    The bearing kit comes complete and it looks like you just bolt it on, but I can't imagine it being that simple???
    Any help or how to guides???
  2. Re: Wheel Bearing
    Nov 2008
    Huntingdonshire
    I do believe it has to be pressed on to the stub even though it looks like it just bolts on like the rear bears do.
    Just to add, the rears are real a easy to change.
  3. Re: Wheel Bearing
    Jul 2007
    somerset
    8 Post(s)
    I think you will find that a new front wheel bearing will come complete with the aluminium casting, it may need the hub pressed onto the bearing, but it's basically 4 bolts and it's on.
  4. Re: Wheel Bearing
    Aug 2007
    Newport, Wales
    7 Post(s)
    Just came accross this image on eBay:
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  5. Re: Wheel Bearing
    Mar 2009
    Kidderminster, Worcestershire and Tewkesbury, Gloucestershire
    can I ask how easy is this to do, I think I need to do my front tomorrow. Can you press the hub into the bearing with a vice?
    any advice appreciated!
    phil
    2007 A6 2.7TDi Avant Manual S-Line
    2003 A4 B6 Avant 1.9 TDi Quattro Sport, Manual -Sold
    1999T A6 C5 Avant 2.5 Auto, 244k -Sold
    2005 STM Phoenix R1 powered, 1988 205 Gti 16v tarmac rally car . . and a few motorbikes
  6. Re: Wheel Bearing
    Mar 2009
    well I had the one bearing changed, looks like the other one wants doing now.
    When removing the old bearing and it's carrier from the front upright will the hub come out the back in one, then press the hub out using a press. Is it possible to do using a large vice?
    If not I will endeavour to buy a press, something I will find useful periodically.
    All advice appreciated!
  7. Re: Wheel Bearing
    Oct 2010
    Middx, UK
    i will need to have this done too - has anyone replaced the fronts on their B6 at home or is a press required? Also, which bearings are suggested? For my Corrado, GSF & ECP bearings are certainly given a wide berth (Topran and some other non-descript makes). Is there an SKF or NSK (or other 'proper' brand) equivalent available?
    A4 B6 S-line, 90k miles
  8. Re: Wheel Bearing
    Mar 2009
    it's a topran one in the OSF on mine that was done 9 months ago and looks like it's gone again. The NSF one (2 months ago) was a genuine VAG one from TPS for £60. Only about £10 more than the pattern topran one.
    I struggle with pullers etc for 3 hours to get mine out and took it to a garage. They needed 10 tons to press it out!
  9. Re: Wheel Bearing
    Oct 2010
    Middx, UK
    thanks for that Phil. Looks like i wont be doing myself then! Will try and get some pics from when the garage changes it for me.
  10. Re: Wheel Bearing
    Mar 2009
    i've done cambelts on 2.5 V6's but the wheel bearings beat me! I think rears are easy enough
  1. renew wheel bearings without joint pain
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-12-2009, 10:10 AM
  2. Question Wheel bearing noise not a Wheel bearing
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2009, 10:31 PM
  3. Front wheel bearing replaced - what have they got wrong?
    By melluish in forum Early Passat Forum - Pre 97
    Last Post: 17-03-2008, 01:11 AM
  4. Replies: 3
    Last Post: 07-07-2007, 04:25 PM
  5. How does the Quattro system work?
