Thread: Intermittent idle problem - tdi 130 - Please help :(
  1. Intermittent idle problem - tdi 130 - Please help :(
    Nov 2006
    Barnsley, South Yorkshire
    Alright chaps!
    ok my TDi 130 is playing up, but its a intermittent problem and its not showing any error codes on vagcom.
    Basicly, when you start it up, it revs up and down really fast for about 1 second, then idles just above 1000rpm. Also when you rev the car, there is a slight delay when you lift of the pedal and when the revs start to drop.
    Like i said, its a intermittent problem and when it's ok, it idles just under 1000rpm and doesnt rev its **** off when you start the car up.
    Also, im sure its only having the problem when the car is warm... not 100% sure on that though.
    Could get a sound recording if you guys dont know what i mean about the reving when i start it up...?
    Anyone had this problem?!?! Please Help
    7 Post(s)
    If it were mine I'd look into giving the EGR valve a clean.
    Do a search on this (both here and elsewhere) it causes all manner of problems.
  3. Re: Intermittent idle problem - tdi 130 - Please help :(
    hi friends
    i have a similar problem i have a tiny skoda felicia 1.3 gli petrol.it started well but if it stopped i would crank long enough but will not start unless i wait for about 3...4 mins. now what i did is that i opened the top black cover over the air inlet n cleaned the carbon deposit with a injector cleaner spray.now a new problem has started the idle speed is1100 revs and as u drive the revs stick to 2500 revs until i tap on the acc. pedal revs then drop to 1100 which is very hi idle rev
    acc. cable is not sticky no fault found on the diagnostic mc. pls help
  1. Intermittent Brake Light Problem
    By dermot in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-04-2008, 02:55 PM
  2. Intermittent Lights problem
    By Clarky3007 in forum 80 - 90
    Last Post: 21-04-2007, 07:44 PM
  3. Intermittent knocking problem
    By Tanuki in forum Audi A4 - Archive Topics
    Last Post: 24-02-2007, 12:56 PM
  4. Intermittent problem
    By EDD001 in forum Archive posts
    Last Post: 30-01-2007, 12:25 PM
  5. a4 intermittent smoke problem
    By topcat5705 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2006, 09:56 PM
