Thread: Replace indicator switch on Passat B5
  1. Replace indicator switch on Passat B5
    Will shortly be replacing Indicator switch on my Passat B5. Does anyone know off any tips that might be of help. Or any links that I may go to, and show how the job is done.
  2. Re: Replace indicator switch on Passat B5
    Norfolk
    Remove battery terminals. Remove drivers airbag (small screwdriver thru holes in back of wheel)..Mark position of steering wheel to column. Undo nut or bolt. Bash wheel to get it off.
    Undo connectors. Remove couple of screws holding top cover. There is another 4 screws and a bolt to remove. This should leave you able to pull off the switch. First undo all the connectors and look for one more bolt at the back. When you refit everything you need to maintain a 3mm gap between the switch and the steering wheel. This sounds worse than it is. Good luck.
  3. Re: Replace indicator switch on Passat B5
    Indicator changed and surprise surprise its not solved the problem. Wiring checked from ccm, all hazards working perfectly, so the lights are not the problem, switch obviously not the problem, relay/switch has been replaced with a new one, maybe thats faulty as well.
  4. Re: Replace indicator switch on Passat B5
    A Galaxy Far Far Away....Derry
    might be the rlay which is inside the hazard light switch/button.is it making a clicking noise that would drive you nuts?
    Jack
  5. Re: Replace indicator switch on Passat B5
    Norfolk
    The wiring from the relay on the hazard switch is ok because the hazards work. The indicator stalk is ok. So Either the hazard switch/relay has an internal wiring fault or there is a fault between the indicator stalk and the relay. Look at relay wiring. Black & green is right indicators. Black & white is left indicators. These should both flash 12v on, 0v off when hazards are on.
    Black/white/green wire is output to indicator switch. With indicator on (left or right) this wire should flash 12v on, 0v off. Check this same wire is flashing at the indicator stalk. Indicator stalk black/green is right. Black/white is left, check these for 12v on and 0v off. If you use a 12v tester it may affect the speed of flashing. Good luck.
  1. new passat b5
    By bennett in forum New Member Introductions
    Last Post: 10-09-2009, 08:39 PM
  2. How To Replace Passat Boot Lock mechanism
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2009, 12:49 PM
  3. (estates/wagons) Audi A4 vs Audi A6 vs Passat
    By passat938 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-05-2009, 01:40 PM
  4. "How To" make s6 leds to passat b5 ;)
    By muratcantona in forum Volkswagen
    Last Post: 28-03-2008, 09:12 PM
  5. New Highline Model Adds Value Boost To Passat Range
    Last Post: 13-02-2008, 08:13 PM
