Thread: Only the high level brake light and flahing coil light
  1. Only the high level brake light and flahing coil light
    May 2007
    My daughter's Mk 4 golf suddenly has a flashing yellow coil light on the dash. Engine is OK. Local garage said probably brake light switch. Checked brakes and sure enough lower brake lights both out but high level Ok. I changed brake light switch which was a four pin but no change. Checked Haynes manual but this only shows wiring for a two pin switch. My guess is that the bottom lights must go through a relay but I don't know which one. Does anybody have any ideas please
    Feb 2006
    is still only one high level light working? or none now?
    fit two new bulbs each side....you can have just two blown bulbs causing a light on the dash to come on as it sensors an open circuit.
    Feb 2006
    also..u need to get fault erased...always a gud idea to clear old faults once rectified.
  4. Brake light problem - high level light OK
    May 2007
    Hi After changing switch no change - high level light works, still both brake lights not working and coil light still flashing. I did check bulbs but both looked OK. If I change the bulbs and it fixes the brake light how do i re-set the fault light on the dash?
  5. Thumbs up Brake light problem - high level light OK
    May 2007
    OK I did as you said changed both bulbs. Blimey it fixed it. Both brake lights now work and no flashing on the dash. Many thanks. - Bob
    Feb 2006
    if it was brake light switch faulty....... the high level light wouldnt have worked either. so had to be two bulbs blown. im glad u got it sorted.
    just hope you adjusted ur brake light switch correclty as i seen alot of mechanics do it wrong and cause problems.
  1. Brake Light / Tail Light Changing Avant
    By Gazz in forum Audi A4 - Archive Topics
    Last Post: 20-11-2007, 10:23 AM
  2. Passat - Oil level warning light.
    By Brian Rouse in forum Archive posts
    Last Post: 22-09-2007, 01:56 PM
  3. Golf MK IV High-Level Brake light
    By Braby in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-06-2007, 04:38 PM
  4. Brake fluid warning light with ABS light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-04-2007, 03:28 PM
  5. Passat Estate High Level Brake Light
    By JRPdark in forum Passat - Archive Topics
    Last Post: 13-09-2006, 12:23 PM
