Thread: rear washer jet
Results 1 to 8 of 8
  1. rear washer jet
    rosieandjim Guest
    anyone ever replaced the rear washer jet on a mk5 golf.
    is this a diy job or do i book it in to main dealer.
  2. Re: rear washer jet
    Southern County Softy
    20 Post(s)
    Why ? are you not getting water through it..
    The pipe inside is known to pop off, you'll have to remove the boot trim to get at it..
    A4 2.5 tdi QS (mapped)
  3. Re: rear washer jet
    rosieandjim Guest
    Correct, getting no water, had new washer pump fitted, replaced 2 front jets and still no water at the rear.
    Can you tell me how to get the trim off?
  4. Re: rear washer jet
    jonda Guest
    i had a similar problem with mine not too long ago. the top cap covering the actual nozzle just pops off, and so does the nozzle. i cleaned mine out with a pin etc and hey presto it worked again. perhaps try that first?
  5. Re: rear washer jet
    rosieandjim Guest
    i have done this no joy
    thanks any way
  6. Re: rear washer jet
    jonda Guest
    take it u can hear the pump working.
    haynes manual describes how to take the panel off.
    silly question but have u tried squirting the jet without the nozzle on?
  7. Re: rear washer jet
    rosieandjim Guest
    pump is working.
    i am going to check if pipe has come off,if not then i will try it without nozzle on.
    thanks
  8. Re: rear washer jet
    rosieandjim Guest
    sorted this problem.
    removed tailgate trim, checked washer pipe , it was ok, tested with pipe off, water coming out, tried to clean jet, no joy.
    so replaced with new one everything working fine.
  1. How To Un-block your Avant rear washer jet
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-02-2019, 01:49 PM
  2. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  3. Rear washer jet?
    By AWH in forum Chat - Completely Off Topic
    Last Post: 01-11-2008, 02:40 PM
  4. How does the Quattro system work?
  5. Help please Re: Rear washer jet.
    By Big_E in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:29 PM
