Thread: Service Indicator Question??
Results 1 to 9 of 9
  1. Service Indicator Question??
    Jul 2008
    Tullow , Ireland
    I'm wondering if anyone can help me out. I'm servicing my mums 2002 A4 2.0. Is there anyway I can reset the service indicator myself without bringing it to a garage??
  2. Re: Service Indicator Question??
    Nov 2008
    N/A
    Try this
    With ignition off, press and hold middle button on right side of instrument panel. Turn ignition to the "ON" position. Release button. "SERVICE!" or
    "SERVICE IN xxxx MI" will appear in display. Press right hand button on right side of instrument panel until display clears. Turn ignition off.
  3. Re: Service Indicator Question??
    Sep 2007
    UK, North East
    You can definately do it and I think that solution above is correct (Ive done mine twice now). If it doesnt work, a search for 'Gendan service light reset' should give you the solution.
  4. Re: Service Indicator Question??
    Apr 2009
    London
    Have you got your owners manual? Its in there for sure......
  5. Re: Service Indicator Question??
    Aug 2009
    Novi Sad
    Quote Originally Posted by benjie View Post
    Try this
    Benjie is right, i did the reset on mine A4. Hold the 'wrench' button, put the key in ignition, turn the key, when 'service!' appears, press '0,0' button, and that's it.
    After few hundred miles your display will show you when is the next service due.
    All this is already on the forum somewhere.
    Cheers.
    Audi A4, B6, 2001, 1.9tdi 96KW, 5 speed.
  6. Re: Service Indicator Question??
    Nov 2008
    N/A
    Glad it worked, yes it's in the how-to section, but I closed the window in firefox before I could link to the page!
  7. Re: Service Indicator Question??
    Jul 2008
    Tullow , Ireland
    Thanks for the replys..
    The instructions that you gave me worked and now the service light has stopped coming on but before when audi serviced it when I turned the ignition on it used to display " service in 66 miles or 66 days" etc now nothing is coming up..Is there away of getting the miles and days countdown timer back on??
  8. Re: Service Indicator Question??
    May 2008
    Elgin, Scotland.
    Quote Originally Posted by ray77 View Post
    As ray77 says the service due miles should come up after doing a hundred miles or so when the system figures out how long to go to next time.
    Colin
    __________________
    2008 Audi A4 Avant 2.0 Tdi SE
    2000 Audi Allroad 2.7T 307bhp
  9. Re: Service Indicator Question??
    Jul 2008
    Tullow , Ireland
    cool thanks
  1. XP - Very Slow on Start up...
    By RickT in forum Home Tech Shed
    Last Post: 16-08-2010, 05:56 PM
  2. Please Help Car switched from Long Life to Time / Distance service by accident?!?
    By wookiee in forum Golf MK5 - 2004 - 2009
    Last Post: 18-07-2010, 11:25 PM
  3. Service due - want to change from vaiable to fixed
    By Tman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-01-2008, 11:06 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
