Thread: ABS Fault Light on W Reg Golf
  1. ABS Fault Light on W Reg Golf
    Jan 2010
    glasgow
    Hi All
    During the recent cold snap the battery on my Mk iv golf lost it's charge as I hadn't started it for a few days. I took out the battery, not as simple as I had expected, and charged it over night. I have refitted the battery, but now the ABS warning light and the Exclamation light to the right of it are on constantly. Does anyone one have any idea why this would be the case? I know very little about the workings of cars. Would the battery being disconnected and returned have any baring on the ABS? Would this simply be as a result of the cold snap? Or is it just a coincidence that both things happened at the same time? Any help would be much appreciated.
    Thanks in advance
    John
  2. Re: ABS Fault Light on W Reg Golf
    Canada
    Drive it a few yards and the ABS and traction control light should go out. It need the recalibrate. My MK5 does the same.
  3. Re: ABS Fault Light on W Reg Golf
    Jan 2010
    glasgow
    Thanks for the response onzarob, but I have been driving it and there is no change on the dashboard. I suspect I will need to get the fault diagnosed to establish the problem.
    John
  4. Re: ABS Fault Light on W Reg Golf
    Canada
    It might just need clearing and all will be well.
  5. Re: ABS Fault Light on W Reg Golf
    A low voltage battery will activate the control light and there will be a fault logged in the ABS control unit,you will need to delate the fault
  6. Re: ABS Fault Light on W Reg Golf
    Jan 2010
    glasgow
    Thanks for the response Kenney, to my untrained mind this would seem like a likely reason for the fault as there was no indication of a fault before the flat battery. How would I go about deleting the fault? Should I just take it to my local dealer and get them to have a look? I assume my ABS will still be working under these conditions?
    John
  7. Re: ABS Fault Light on W Reg Golf
    Any garage with diagnostic equipment can read and delete the fault code.The ABS is not functional if the control light is on
  1. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  2. ABS warning light fault.
    By superkp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-08-2009, 10:46 AM
  3. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  4. 1999 passat ABS light help
    By jonny VDUB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2008, 01:25 PM
  5. ABS light Issue
    By gnasher in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-01-2008, 08:32 PM
