Thread: fuel injectors for Audi 80 B4,ABK engine
Results 1 to 10 of 10
  1. fuel injectors for Audi 80 B4,ABK engine
    Jan 2010
    Sofia Bulgaria
    Can anybody help me with some technical data about fuel injectors for Audi 80,ABK engine.What is the flow rate (cc/min) and resistance (ohm)?
    According to ETKA the part number is: 037906031R
    Many thanks in advance!
  2. Re: fuel injectors for Audi 80 B4,ABK engine
    Specification
    Bosch injector: 15 ... 17 ω
    Siemens injector: 13.5 ... 15.5 ω
    There is no given flow rate for the injectors,but there is the one control Checking freedom from leaks and spray pattern of injectors.
    There is also the fuel delivery rate control of the fuel pump
  3. Re: fuel injectors for Audi 80 B4,ABK engine
    Jan 2010
    Sofia Bulgaria
    Quote Originally Posted by kenney View Post
    Specification
    Thank you,Kenney!
    One more question,if you have any idea...is that true that the SIEMENS part number which is shown in ETKA as 037906031R corresponds to BOSCH part number 0280150902?
    My present injectors have been cleaned in the same manner as it shown in the following link: http://www.injectorcleaning.co.uk/spray.htm ,but after that procedure the car is difficult to start hot.That's why I'm going to change them with new ones.
    The fuel pump is brand new so it's ok.
  4. Re: fuel injectors for Audi 80 B4,ABK engine
    Sorry can't help with the part id but as regarding difficulty in warm start,that is were the injector leak control might show up a fault
  5. Re: fuel injectors for Audi 80 B4,ABK engine
    Jan 2010
    Sofia Bulgaria
    [QUOTE=kenney;461597]Sorry can't help with the part id but as regarding difficulty in warm start,that is were the injector leak control might show up a fault[/QUOT
    Anyway,I would like to thank you about attention and help.
    Few Audi 80 owners explained me that very often the reason for difficult warm start is a small leakage caused by supersonic inejector cleaning.
  6. Re: fuel injectors for Audi 80 B4,ABK engine
    Gwent
    Warm start problems can be due to a few other faults,
    On the ABK, I would also check:
    ECU Relay (30 on top) slide the cover off and check carefully for poor soldering.
    G62 coolant temp sender.
    O2 sensor
    Hall sender inside the distributor
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  7. Re: fuel injectors for Audi 80 B4,ABK engine
    Jan 2010
    Sofia Bulgaria
    Quote Originally Posted by scotty33 View Post
    O2 sensor
    Hi Scotty,
    Regarding the O2 sensor it has been checked and it's working properly.
    I'll check ECU relay and hall sender too,but I didn't got where is the G62 coolant temp sender...I guess you mean the blue one on the picture below:
  8. Re: fuel injectors for Audi 80 B4,ABK engine
    Gwent
    Yes, I think it is the blue one
  9. Re: fuel injectors for Audi 80 B4,ABK engine
    Jan 2010
    Sofia Bulgaria
    Well,I'll replace the present blue sender with a new one...If this sender is the reason why my car don't starts warm I'll be lucky.
  10. Re: fuel injectors for Audi 80 B4,ABK engine
    Jan 2010
    Sofia Bulgaria
    I'm pleased to share with you,that the warm start problem is solved!
    I've received a remanufactured injectors,replaced the old ones by them and the annoying feeling of difficult ignition disappeared.
    It seems that sometimes the supersonic injector cleaning causes warm start difficulties.
  1. Please Help ***?? - Engine serial removed!
    By TheRealYeti in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-08-2010, 08:06 PM
  2. Question fuel injectors for Audi 80 B4,ABK engine
    By Docho in forum 80 - 90
    Last Post: 13-01-2010, 11:52 AM
  3. allroad tdi 2.5 air in fuel :(
    By m6rk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-12-2007, 01:09 PM
  4. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
