Thread: xenon headlights
  1. Re: xenon headlights
    Jul 2008
    Hi there mate, I recently (luckily before the bad weather) upgraded my headlights to HID's. It's a very simple job, I think the hardest thing you will have to do is cut the clip that holds the bulb in the housing.
    I purchased this set http://www.hids-direct.co.uk/hid-con...its-p-265.html and it took less than an hour to fit. There are a few guides knocking about but it's pretty self explanatory and definately a worthwhile modification. I personally think a cheap £30 ebay set will work just as well and just as long as the more expensive kits out there but the choice is yours.
    I went for the 5000k kit which gives a more OEM look, however for maximum light output, i'd suggest the 4300k. Keep us informed of how it goes.
  2. Re: xenon headlights
    Mar 2009
    Hi mate,
    Many thanks indeed. Is there a particular bulb type that I should have? Also, did you notice a significant difference when your kit was put in?
  3. Re: xenon headlights
    Jul 2008
    Quote Originally Posted by essexexpat View Post
    Hi mate,
    For the dipped beam you need to get H7 bulbs. I'm fairly sure the full beams are H7 too but it's up to you whether you upgrade these too. I did notice an improvement as the old standard bulbs were WOEFUL and were in my opinion dangerous. It's well worth upgrading - not a costly job to carry out, but very effective.
  4. Re: xenon headlights
    Mar 2009
    Many thanks guys.
  5. Re: xenon headlights
    Apr 2009
    Preston
    have changed dipped beam and main beam with xenons and both are H7.
    Moderator edit:
    If you're not approved to advertise your company, don't
    Read the Rules
    Y90USF
  1. Question Can Xenon headlights be swapped in with halogen wiring loom?
    By DavidA4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-01-2012, 12:37 PM
  2. Passat B5 Xenon Headlights
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2010, 01:51 AM
  3. I've got Xenon headlights, now what?...
    By x_cessive in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 10:08 PM
  4. Xenon Headlights to none OEM Xenon Cabriolet
    By brooksyboy in forum Chat - Anything with wheels
    Last Post: 12-10-2009, 11:48 PM
  5. Replies: 2
    Last Post: 10-07-2007, 10:16 AM
