Thread: Allroad won't Lower
Results 1 to 10 of 10
  1. Allroad won't Lower
    Ayrshire, Scotland
    18 Post(s)
    I thought i would share this fault I have had twice now on my allroad.
    I had this about 10 months ago when the car would raise OK but not lower resulting in me getting it stuck at level 4 with the Dash suspension error light on also posted on here, but it happened again yesterday,
    Vag com fault:
    01397 - Venting Solenoid for Level Control (N111)
    31-00 - Open or Short to Ground
    The last time it was a broken wire to the solinoid on the compressor which I joined and so I thought it would be my joint which had failed, but on investigation, it turned out to be a new break in the wire, on further investigation there had been a 3rd repair prior to me owning it and so these 2 wires going to the solenoid have caused some trouble now and in the past.
    I thought I would post this to save others time if you have the same error as these wires may be prone to damage or breaking.
    attached are some pictures in case any others have the same symptoms in the future.
    1st shows the side to locate solenoid & compressor:L1000489edit.jpg
    Next is 2 wires going to solenoid, yellow wire being poory patched previous to my ownership:L1000494edit.jpg
    close up showing broken wire and previous join taped up:L1000493.jpg
    I removed the electrical plug and in true Audi Build i could neatly remove the connections from the housing and solder a new wire removing old jointed wire. Car goes down again great when you get a fix without costing ££££'s.
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
    3 3 0
  2. Re: Allroad won't Lower
    Feb 2007
    Good info and good pics for the knowledge bank.
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  3. Re: Allroad won't Lower
    Dec 2009
    Birmingham UK
    Yes cheers for that. Another one to add to the possibles when suspension does weird stuff!
  4. Thumbs up Re: Allroad won't Lower
    Jan 2010
    bradford
    great stuff
  5. Talking Re: Allroad won't Lower
    Feb 2015
    România
    very good advice. excellent explanation. thank you.
  6. Re: Allroad won't Lower
    Apr 2016
    Eastbourne
    Hello,
    Anyone knows if at audi a8 2007 this solenoid are in the same location?
    I've tried a few hours to find it, but no chance.
    At a8 looks a bit different underneath the car, but might be my mistake.
    Someone can put me in the right direction please?
    Thanks, Flavius Michael
  7. Re: Allroad won't Lower
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by Pripasu Flavius View Post
    Hello,
    The N111 solenoid is on the air suspension compressor, the compressor on the A8 is under the car in front of the front wheel, access under or through wheel arch liner.
    What is your suspension symptoms?
    Regards
    Andy
  8. Re: Allroad won't Lower
    Apr 2016
    Eastbourne
    Thank you Andy for your quick response.
    The air suspension left on the higher level and when I've put the diagnose, I've got the same code errors like in this thread "01397 - Venting Solenoid for Level Control (N111)
    31-00 - Open or Short to Ground".
    I found it now, and now I'm trying to see if I can get sorted out somehow or I have to buy a new compressor.
  9. Re: Allroad won't Lower
    Ayrshire, Scotland
    18 Post(s)
    If the error is Open or Short to Ground it’s not a faulty valve it is most likely the wires or plug connection, inspect the 2 this wires going to the n111 valve, it’s the connection on the plastic body of the compressor
  10. Re: Allroad won't Lower
    2018 Post(s)
    That is the valve block on the compressor, genuine they are daft money but there are lots of cheap aftermarket ones which work.
  1. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  2. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  3. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
  4. New Audi A6 allroad quattro ready to tackle British soil
    Last Post: 05-04-2006, 08:13 PM
  5. At home on all roads and tracks - Audi A6 allroad quattro
