Thread: Mirror Bulb Replacing
  1. Mirror Bulb Replacing
    Jan 2010
    Hello
    Has anyone replaced the indicator bulb on the n/s mirror on a 57 reg polo? Can it be done easily @ home or is it a dealer job.
  2. Re: Mirror Bulb Replacing
    Bristol
    It's different on mine (it's pre-facelift), but I'm sure you can get the casing off, you normally can.
  3. Re: Mirror Bulb Replacing
    Jan 2010
    Thanks for your reply, however i'm after a 'how to' bulb replacement answer if possible as i've not done this type of thing before.
  4. Re: Mirror Bulb Replacing
    Jan 2010
    Attempted to tackle this bulb replacement. Got the mirror casing off & then noticed 1 tor x screw which i undid which partly loosened the bottom casing, however there is a 2 wire lead connecting to a block which i struggled to unplug as it wouldnt un clip. So ended up putting it back together, unless someone knows how this block connsctor comes off?
  5. Re: Mirror Bulb Replacing
    Jan 2010
    Had another go & managed to get the block off, seems that the lights are really small leds.smt etc & soldered to a circuit board. Looks like you have to buy the circuit board with the lights pre soldered.
  1. Question Replacing ABS Control Unit
    By jonsgp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2009, 02:12 PM
  2. Please Help Brake Piston Question on Replacing rear discs
    By muchos04 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-08-2009, 07:31 PM
  3. Replacing Heater Matrix - How?
    By gold682 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-01-2009, 11:46 PM
  4. Number plate light, replacing
    By irishyop in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-12-2007, 03:16 PM
  5. replacing the KKK with a Garrett
    By biglockie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-10-2007, 09:49 AM
