Thread: Rear wash pipe connections ?
  1. Unhappy Rear wash pipe connections ?
    Sep 2007
    My rear wash stopped working a while ago...
    I've today reconnected the pipe connector above the LH rear tail lamp again (as came off in the last cold spell also).
    I've also disconnected the pipe at the rear wiper motor, & operated the washer & nothing comes out
    ironically......when re-connected...theres a small supply of washwater out of the FRONT washers when the REAR screen wash is activated ?
    But nothing out of the rear ?
    Where are all the other wash pipe connections located ?
    I'ts a 2002 model B5 1.9TDI 130 Sport Estate
  2. Re: Rear wash pipe connections ?
    Aug 2007
    I've got a similar problem - see my recent "Please help: Rear washer..." etc. thread. I've included some pictures which may help (at least identify the problem).
    Mine has separated just after the reservoir - undo the torx screws holding the wheelarch liner on, peel it back and have a look. You may have the same problem that I have.
    Unfortunately, if you do... I have no idea where the pipe actually goes - and if you work it out I'd really appreciate knowing.
    Good luck!
    Shades
  3. Re: Rear wash pipe connections ?
    Aug 2007
    I've now fixed my problem with a non-working rear washer - a pipe connection not far from the pump had "popped". Take a look at my thread, with pictures, that may well help you with yours.
    Good luck...
    Shades
  1. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  2. No water at rear wash wipe - how to gain access
    By ian davies in forum Golf MK4 - 1999 - 2004
    Last Post: 21-04-2008, 09:47 PM
  3. Touran rear windscreen washer pipe problems
    By touran wales in forum Touran - Sharan - Caravelle
    Last Post: 13-01-2008, 02:27 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
