Thread: 2nd gear crunch when cold
Results 1 to 10 of 18
  1. 2nd gear crunch when cold
    Jun 2008
    hi anyone had 2nd gear crunching when cold ,have just had audi fit new 2nd gear and hub assembly and still not good .any takers
  2. Re: 2nd gear crunch when cold
    Jan 2009
    Ireland
    Yep, I get the same. I just try not to use 2nd when it's cold or go into it really slowly.
    2005 Audi A4 2.0 TDI S-Line I need to start the mods now
  3. Re: 2nd gear crunch when cold
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Warranty? Take it back.
    Alan.
    VW T6 150 DSG Camper £££
  4. Re: 2nd gear crunch when cold
    Oct 2009
    Cleveland, OH
    It sounds like you might want to do a fluid change. We've had GREAT results with Redline MT. It has allowed for smoother gifts as well as off power/on power throttle mashing. Essentially, Redline MT smooths out gear boxes wonderfully.
    Click here for Redline MT
    :: www.ECStuning.com :: IS NOW OPEN TILL MIDNIGHT EST FOR PHONE ORDERS!!
    Phone: 1.800.924.5172 - 8:30 am to 12:00 am | Email: Pete@ecstuning.com | Questions? PM us for a quick response!
  5. Re: 2nd gear crunch when cold
    Southern County Softy
    20 Post(s)
    On my B6, I had the gearbox changed twice due to crashy gear changes.
    My car has just done over 60K, the changes are now starting to smooth out
    A4 2.5 tdi QS (mapped)
  6. Re: 2nd gear crunch when cold
    Dec 2006
    Oh yes... my B6 TDI 6 speeder... when cold it crunched .... changed the fluid using standard Audi gear box oil.... very marginal change......
  7. Re: 2nd gear crunch when cold
    Mar 2008
    Old Wessex
    This seems very common on the 6-speed manual....
    My Passat is very notchy from cold, particularly in 1st, 2nd and 3rd gear, but smooth when warm. It doesn't crunch but it's quite clunky (if that makes sense). I tend to take it slow for the first 5 miles and everything seems to loosen up.
    I've done loads of research on this and I still don't know if there is a proper fix. I don't know if it's the gear oil or the synchros at fault (or maybe something else entirely?)
    - VW Golf 1.9 GT TDI (130) - 2003
    - VW T5 Camper - 2.5 TDI - 2008
    - VW Passat Estate - 2.0 TDI - 2010
  8. Re: 2nd gear crunch when cold
    Nov 2008
    Beds
    Mines the same, fairly horrid when cold but is fine when warm albeit abit clunky occasionally.
    Glad its not just mine!
    Audi A4 B6 Avant Sport 1.9TDI (SOLD)
    His: BMW 123d Coupe Auto
    Hers: Audi A4 B8 2.0TDI 143 Multitronic
  9. Re: 2nd gear crunch when cold
    middlewich uk
    i have found it to be a little clunky when cold but i used to have a 106 quiksilver and that was horrid trying to get 2nd when cold you had to allways go 1st to 3rd
  10. Re: 2nd gear crunch when cold
    Feb 2010
    Tampere-Finland
    I'm also having crunchy feelings when changing to 2nd gear, sometimes when changing to 3rd too. I've always thought that this was due to a cold climate [in Finland ]
    But then again is it the cold or should I change the transmission oil? Anyway the car is going for a flywheel operation next week (due to vibrating chassis while idle in traffic lights etc).
    Any ideas?
    Thanks in advance
  1. Question Passat 2nd, 3rd gear syncro wear crunch?! which oil/what to do
    By passat938 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2009, 06:56 PM
  2. Notchy 1st to 2nd gear change
    By kimandsally in forum Touran - Sharan - Caravelle
    Last Post: 21-12-2008, 08:25 PM
  3. 2nd gear crunch noise
    By DAVIDBLUEJEAN in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-02-2008, 11:35 PM
  4. Lost 2nd gear, synchro? common failure?
    By Dave Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2007, 01:32 PM
