Thread: Handbrake locked on - frozen?
Results 1 to 10 of 20
  1. Handbrake locked on - frozen?
    May 2009
    Wirral
    Hi. My handbrake won't release. The dashboard handbrake button is flashing orange and there is a brake warning light on the dash display.
    Tried putting the car into reverse and seeing if I could release the brakes that way. Three wheels are moving but rear drivers side wheel is not turning at all.
    Minus 2 degrees here and a lot less than that last night.
    Anything else I can try? Would getting a hairdrier to heat up the rear calipers help in anyway or spraying boiling water in there?
    No sign of warmer weather on its way so need to try and find a fix.
    2006 Passat Saloon 2.0 SE TDI SatNav
  2. Re: Handbrake locked on - frozen?
    May 2009
    Wirral
    Just a bit more detail. Even though the parking brake button is flashing orange I can still hear what sounds like the caliper motor moving for about one second.
    Does the handbrake lock the caliper on both rear wheels or just one?
  3. Re: Handbrake locked on - frozen?
    Dec 2009
    14 Post(s)
    I would imagine both. Not that I have my passat yet though.
    I would suggest jacking car up and removing wheel and see what the car is doing.
    Or use your breakdown cover if you have it. And let them sort it. Good luck hope you get it sorted. Something for me to look out for when I get mine.
    Rappy.
  4. Re: Handbrake locked on - frozen?
    Dec 2009
    14 Post(s)
    I would stay clear of hairdryer. Boiling water sounds a good idea.
    I would imagine the passat has rear discs with smaller drums for the handbrake you could try hitting the drum to see if it frees it up.
    Or call your breakdown cover.
    Rappy.
  5. Re: Handbrake locked on - frozen?
    Norfolk
    Do not do anything to the wheels. You have one caliper motor per rear wheel. If you can hear a motor, is it one or both. If one is not unwinding, the brake will stay on and the dash light will flash. This means the car has a fault and can't be moved. It is usually a faulty dash switch. If both motors are rewinding, the car will move even with frozen rear brakes. One trick you can try is disconnecting the battery for ten minutes. That does sometimes work.
  6. Re: Handbrake locked on - frozen?
    Apr 2007
    France
    12 Post(s)
    The handbrake works on both rear discs - no drums
    The callipers may well be working but obviously won't pull the pads off if they are frozen on.
    Someone else on here had the same problem a few weeks back - might be worth doing a search.
    Leave it in gear, handbrake off when it's freezing.
    Follow Martin's advice - better than a search
    Last edited by Quatrelle; 06-01-2010 at 09:57 PM. Reason: Post crossed with Martin's
    1996 Laguna 2.2D
    1977 MGB roadster
  7. Re: Handbrake locked on - frozen?
    May 2009
    Wirral
    Quote Originally Posted by martin1810 View Post
    The car will move if given enough gas - however the rear drivers side wheel is not rotating according to my neighbour. At that point I stopped in case I caused any damage.
  8. Re: Handbrake locked on - frozen?
    Dec 2009
    14 Post(s)
    Pleased the passat does not have drum brakes for the handbrake crap design on my pug.
    Martin's sounds a good tip disconnect the battery.
  9. Re: Handbrake locked on - frozen?
    May 2009
    Wirral
    Thanks. Got a plan of action tomorrow.
    Firstly try disconnecting the battery. This is something I have been meaning to do for a while anyway to see if it resolves the passenger door handle issue (won't open from outside).
    Then if no luck I'm going to remove the rear wheel and see what position the caliper/piston etc is in and see what movement there is. Will dig out my piston rewind tool in readiness.
    I'll report back tomorrow!
  10. Re: Handbrake locked on - frozen?
    Nov 2008
    Lincoln, UK
    Quote Originally Posted by oxtailsoup View Post
    Whatever you do, do not try to rewind any piston. The motors can only be powered in using battery and VAG COM/VCDS software. Martin or Crasher will, I am sure, confirm this.
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  1. Ever wondered what happens when you push the handbrake button whilst driving ?
    By carl s in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-03-2010, 07:39 PM
  2. Passat Electronic Handbrake (doomsday scenario)
    By meoman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2009, 05:52 PM
  3. Question Reversing lights come on/flicker with handbrake
    By Hellsteeth in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2009, 10:26 AM
  4. handbrake lever
    By futsysmids in forum 80 - 90
    Last Post: 17-02-2008, 11:39 AM
  5. Passat Electronic Handbrake Problems
    By wildinthecountry in forum Passat - Archive Topics
    Last Post: 08-10-2006, 05:39 PM
