Thread: rear anti-roll bar
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: rear anti-roll bar
    Nov 2008
    Beds
    Ive done the RS4 RARB mod and it does improve handling slightly, but you can only really feel it when you are properly chucking it about.
    RE front ARB i was told they are the same diameter across the range A4/S4/RS4 so no advantage to upgrading.
    Audi A4 B6 Avant Sport 1.9TDI (SOLD)
    His: BMW 123d Coupe Auto
    Hers: Audi A4 B8 2.0TDI 143 Multitronic
  2. Re: rear anti-roll bar
    May 2008
    Finland
    DBSK, is your car FWD or Quattro? I've been thinking about getting the RS4 RARB but I'm not sure if it'll do any good to a FWD. A stiffer RARB should cause more oversteer, but does it do that in an FWD as well?
    ____________________________________________
    VW Golf Mk.V 2.0tdi 4Motion
    VW Golf Mk.IV 1.4i
  3. Re: rear anti-roll bar
    Nov 2008
    Beds
    Quote Originally Posted by Turbokiisseli View Post
    Mines FWD. Its definately worth doing, i wouldnt say it makes it easy to oversteer, if you really try you can get lift off oversteer but youve really got to chuck it in for that to happen.
    But everyday it makes it alot more stable through high speed roundabouts/corners.
  4. Re: rear anti-roll bar
    Jun 2009
    Winchester
    Which wheels are driven will not affect the corner entry phase which is the one that different ARB thicknesses has the most effect on. Even the mid-corner phase (most stably done under light acceleration) is not hugely affected by the driven wheels. Handling balance and traction are very different things, and which wheels are driven mostly has an effect on corner exit under power. So alterations to spring/damper/ARB settings will largely affect a FWD in a similar way to a Quattro, ignoring the weight differences...
  1. Question Do cracked rear anti roll bar collars cause any handling symptoms?
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-10-2009, 10:34 AM
  2. Passat Anti Roll Bar dia
    By limecc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-09-2009, 09:32 PM
  3. rs6 rear anti roll bar
    By sbt in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-08-2009, 02:44 PM
  4. Split rear anti roll bar
    Last Post: 28-04-2008, 02:31 PM
  5. How does the Quattro system work?
