Thread: Golf IV 1,4 16v engine probs.
  1. Golf IV 1,4 16v engine probs.
    May 2007
    Hi guys!. First mess. Hope you can help me.
    The car is a VW Golf IV 1.4 16v -00 enginecode:AXP
    Question no.1:
    When shifting from first to second gear the car twitch one time and when driving normaly at slow speeds in town or at highway speeds the car twitches ever so little. I've connedted vag-com and noticed that when driving on the highway everything is fine but when slowing down the tempsensor tells the engien that it's colder that it really is. Could this be why the car it twitching from time to time?
    Question no.2:
    The engine is leaking oil. I filled her up to MAX and has now been driving for two weeks. Yesterday when I checked again it was back down on the MIN-mark. Is this a common problem on this engine? Where should I start looking?
    Question no.3:
    I once had a Volvo V70I with a twitching problem. The service-people uppgraded the software for the accellerator pedal. Is it possible to do this on the Golf as well?
    Is it possible to install cruisecontrol on this car?
    Hope you can help med with this
    May 2007
    Anyone, please??
    Feb 2006
    i dont know what u mean by the car twitching
    so dont know how i can help you there
    but as for the oil...can u see any leaks?
    i know that particular engine the oil takes a while to settle in a position and the oil level reading can be misleading. so start the car for a 30 seconds....turn off and let the oil settle for a while then check the level.
    May 2007
    Thanks for your reply.
    By twitching I mean car loosing power for a millisecond.
    I was just looking under the car and I can see some dampnes but mostly where the gearbox is
    Feb 2006
    gearbox selector seal does tend to leak a little....probs what you seeing. that oil will smell fishy and different from engine oil
    if you cant see any leaks...then id say just keep monitoring the level and make sure it dosent drop a significant amount
    remeber as you have to make allowance for the oil being hot and cold. science will tell how it epxands and contracts with temperature and give you slightly different level readings.
    is it a sporadic misfire? like ht leads or spark plugs showing signs of starting to be worn....wait for the fault to worsen as intermittant faults are hard to diagnose.
    May 2007
    No misfires what so ever, just loss of power
    Feb 2006
    if no faults are logged by the ECU or any other clues..struggle to give advice
    sorry
    the coolant temperature sensor would effect your fuel efficiencey and may effect starting from cold...shouldnt effect performance at all.
  1. golf 1.8t 20v turbo probs can anyone help!!!
    By isetta in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-08-2007, 08:39 PM
  2. Golf Fuel Probs/Stalling
    By my1stGTi in forum Golf MK3 - 1993 - 1999
    Last Post: 22-03-2007, 06:24 PM
  3. 1990 Mk 2 Golf 1.3 Gearbox probs
    By radcliffe in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-03-2007, 12:23 PM
  4. help. engine probs
    By gianfranco25 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-02-2007, 09:01 PM
  5. Octavia Turbo Engine check light probs
    By SKODAOCT20vt in forum Octavia
    Last Post: 24-08-2006, 10:01 PM
