Thread: 99 Passat auto- problem with gears- Help!
Hybrid View
  1. Exclamation 99 Passat auto- problem with gears- Help!
    May 2007
    I have a 99 model Vw Passat 1.9 TDi. When setting off, I find that the auto gear box misses 1st gear.
    With normal auto's the car start to move as soon as 'D' is engaged and the foot brake is released. My car doesn't start rolling and as soon as I start to accelarate there is a bump and then the gear engages. Almost like a void.
    The idle rate is bang on and there doesn't seem to be a problem there. I've also found when driving hard the gear change can miss also. The engine revs increase as if in neutral and a few seconds later the gears engage, usual 2nd or 3rd.
    Please help as i've been told by a few people that I would need to recon my gear box. Are they right?
    Kindest regards
    Jum
    banbury,oxon
    might be an idea but have you checked oil level in box..??
    lee
    B5 passat needs a supercharger and does'nt leak
    May 2007
    Hey thanks for the reply. I haven't checked the oil.
    I purchased the car 2 days ago. The seller claims he has had it done, but i can't help but feel skeptical.
    I've got the seller to sort it out for me. He's taken the car to a transmission specialist. Reckon he'l get a diagnostic done.
    Hopefully the problem should be ironed out by Monday. Will let you know what the outcome is.
    Regards
  1. Auto gearbox problem with 02 TDI Passat
    By Kaiser2000 in forum Passat - Archive Topics
    Last Post: 11-11-2007, 04:26 AM
  2. stiff gears in 2001 passat tdi 130
    By paul not in forum Passat - Archive Topics
    Last Post: 02-05-2007, 11:39 PM
  3. Golf TDI MK4 Faulty Gears
    By 2Dcadman in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2007, 12:02 PM
  4. Random auto gears
    By kevster in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-01-2007, 10:10 AM
  5. V6 TDI Auto Problem
    By Kevin in forum Passat - Archive Topics
    Last Post: 05-09-2006, 05:05 PM
