Thread: Repair your headlight switch illumination
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Repair your headlight switch illumination
    Southern County Softy
    20 Post(s)
    Email on it way
    A4 2.5 tdi QS (mapped)
  2. Re: Repair your headlight switch illumination
    Oct 2010
    Middx, UK
    good thread. My headlight switch flickers intermittently, well just the last led for the dipped beam icon on the outer ring. I've resoldered the two pins, although they looked fine to me. Anything else i need to check? Its obviosuly a loose connection somewhere as a slight tap on the side of the dash and it lights nicely, but then switches off again.
    A4 B6 S-line, 90k miles
  3. Re: Repair your headlight switch illumination
    Cork
    Quote Originally Posted by fla View Post
    I had the same intermittant problem. After a while two of them stopped working, so I looked for this guide, couldn't find it, so did it from memory. Replaced 2 led's and 2 dry joints/cracked pcb track. In the process dislodging a resistor which was a PITA to fix. All back together now and working great.
    AUDI A4 Avant 2.0TDI S Line
    | My Slipper |
  4. Re: Repair your headlight switch illumination
    Mar 2010
    South Lincolnshire
    I realise this thread has been quiet for a while but I thought I would give it a go.
    I have a problem whereby the lights within the switch illuminate at initial switch on but go out after about 3 seconds. No amount of tapping the dash will turn them on. Is this likely to be an LED problem or something else?
    Also:
    In the above description a 12v supply was used but a 5v LED was inserted as the replacement. Should I buy 5V LEDs or 12V?
    All help gratefully received.
  5. Re: Repair your headlight switch illumination
    Mar 2016
    Serbia
    @toff
    Thx dude for detailed tutorial.
    I just exchange few led 3 red and one green.
  6. Re: Repair your headlight switch illumination
    Dec 2016
    Netherlands
    Hey guys
    Got a question, I tried to fix the same LEDs as the opening poster, if i touched the most right top led, the two would go on. So i suspected a bad solder point on the LEDs. After soldering they did turn on but blinked both at the same rate. So i tried to solder again but now they are completely dead.
    How come the LEDs blinked at the same rate? And is it possible that the LEDs are broken?
    Where do you guys order the right type LED?
    attemt #1
    attempt #2
    talking about these ..
    1 1 0
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. front fogs
    By paulsa4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-12-2010, 08:06 PM
  3. Question Light switch - intermittent illumination of dipped headlight logo
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-12-2009, 10:56 PM
  4. overheating & burning headlight switch - recurring fault
    By rdlb in forum Golf MK3 - 1993 - 1999
    Last Post: 07-03-2008, 01:17 PM
  5. Headlight Switch Illumination
    By c0l in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2008, 04:41 PM
