Thread: Alhambra 1.9tdi high water pressure
  1. Alhambra 1.9tdi high water pressure
    Dwayne Guest
    My Seat Alhambra 1.9tdi is having problems with high water pressure. it seems to be ok when the expansion tank cap is off but as soon as i screw it on it becomes pressured and bursts a pipe. I have had the head gasket changed but still it pressures. It also doesnt show on the temp gauge that the engine is getting hot but the water is overheating and I do not seem to be getting any hot air through the heating system inside the car. I wonder if its the pressure release valve but haven't a clue where this is. I have replaced the thermostat and when one of the pipes first burst I noticed that the plastic junction that connects the pipes up had corroded which I replaced with a copper one, could it be that a piece of corroded plastic is causing a blockage somewhere?? please help. Dwayne
  2. Re: Alhambra 1.9tdi high water pressure
    Dwayne Guest
    Well I take it no one can help me then??
  3. Re: Alhambra 1.9tdi high water pressure
    Have you checked the coolant pump impeller
  4. Re: Alhambra 1.9tdi high water pressure
    Jan 2010
    Bristol
    Hi, I have the same problem in my Audi a4 1.9tdi (B5).
    It must be related with head gasket or head itself.
    Propably there is a hole in the head between 3rd and 4th cylinder and it gives the pressure to the coolant.
  5. Re: Alhambra 1.9tdi high water pressure
    Before you go pulling the head off,check the coolant pump impeller,you could also try to replace the expansion tank cap
  6. Re: Alhambra 1.9tdi high water pressure
    Dwayne Guest
    But do you think that it would still be losing water if the impeller is broke? Also would it build up such pressure that it keeps bursting pipes??
  7. Re: Alhambra 1.9tdi high water pressure
    Quote from your first post (but the water is overheating)you have replaced the head gasket and assuming you have done the job properly and there are no cracks in the head,I rest my case
  1. WATER PUMP faulty - overheating 1.9tdi PD
    By mystic.bertie in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-05-2009, 03:39 PM
  2. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  3. '92 MKII no oil pressure (0)!
    By 2old2turbo in forum Jetta MK2 - 1984 - 1992
    Last Post: 12-10-2007, 02:30 AM
  4. '92 MkII 1.8 NO oil pressure
    By 2old2turbo in forum Golf MK2 - 1984 - 1992
    Last Post: 06-10-2007, 09:58 PM
