Thread: compatible gearboxs with akl engine
  1. compatible gearboxs with akl engine
    Aug 2009
    manchester
    hi
    can anyone tell me which gearboxs are compatible with the akl engine 8v
    thanks
  2. Re: compatible gearboxs with akl engine
    135 Post(s)
    2033 Post(s)
    Really only the DUU but you will chase your tail around in circles trying to find a box for an AKL, they are such a problem they are in very short supply.
  3. Re: compatible gearboxs with akl engine
    Aug 2009
    manchester
    is it possible to swap the duu gearbox with any that have the codes dus/duw/dlp/ert.
  4. Re: compatible gearboxs with akl engine
    135 Post(s)
    2033 Post(s)
    DUS/DUW will fit but are from diesels and the 3rd/4th/5th gears are different, DLP is fine for an AKL as is an ERT.
  5. Re: compatible gearboxs with akl engine
    Aug 2009
    manchester
    is it possible to take a ERT gearbox from a 54 plate 1.6 seat leon and put it on my 1999 1.6 golf mk4 engine code AKL
    also would it need uprating
  6. Re: compatible gearboxs with akl engine
    135 Post(s)
    2033 Post(s)
    No, on second thoughts and a little more checking I am not 100% sure as a factory original ERT is designed for the small engine 1.6 16v application and uses a different bell housing to the DUU, DUS and DUW but the replacement part number is the same for all so I am a little unsure. I won’t mix and match boxes myself, I will only fit codes VAG decree as being correct.
  1. Court Hearing - Information required...
    By motyourcar in forum Chat - Anything with wheels
    Last Post: 17-08-2011, 09:31 PM
  2. Replies: 1
    Last Post: 07-07-2009, 10:48 AM
  3. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  4. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
