Thread: Cleaning a blocked DPF
Results 1 to 10 of 21
  1. Re: Cleaning a blocked DPF
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Luckily i dont have a DPF on my model,but pleased to hear yours is now sorted.And a good write-up for those who do have problems with the DPF !
    Alan.
    VW T6 150 DSG Camper £££
  2. Re: Cleaning a blocked DPF
    May 2007
    knee deep in clunge
    14 Post(s)
    If you follow the correct process and all the associated sensors are correct then emergency regen is required only if you have failed to carry out the correct driving profile when prompted by the regen light displayed on the dash.In your case the emergency regen would simply have done this for you but only via vcds or vas pc.At this time of year we find the tubing pipes freeze causing incorrect pressure readings but most common cause I have found is the g450 sensor.
    The emergency regen is pretty successful but you need a good 20 mile stretch of motorway and a second person observing the vcds readings.
    You have gone to alot of effort so I commend you but there was no need.
    If in doubt next time check the exhaust sensors read correct and g450 pressure is within spec followed by removing the g450 pipes and cleaning them.
    NEVER IGNORE THE PRE REGEN WARNINGS AND DONT REMAP OR ADD CHIP BOXES TO PD DPF ENGINES
    Attachment 7645
    If you see either fault code
    08194 P2002 particle filter bank 1 - malfunction
    this is your fault code and you require the ecu flash updating and this in turn with the emergency regen would resolve your issue (The dealer would not have suggested a new dpf unless this failed !!!!!).The update heats the dpf quicker amongst other mods associated with dpf monitoring and ash content
    09263 P242F particulate filter maximum loading exceeded
    Check with your dealer for the relevant ecu update or post your engine code and also a current vcds log with address 01 full data so I can see your sw version
    vag diagnostics, retrofits and general repairs
    2 0 0
  3. Re: Cleaning a blocked DPF
    Jul 2008
    Stafford
    Quote Originally Posted by a8 tech View Post
    If you follow the correct process and all the associated sensors are correct then emergency regen is required only if you have failed to carry out the correct driving profile when prompted by the regen light displayed on the dash.In your case the emergency regen would simply have done this for you .....
    Thanks for the comments especially the attached file. Wish I had asked you before...
    I'm a bit puzzled though about the DPF loading percentage. Mine was 174% according to VCDS and your attached file says >90% cannot be emergency regen'd. But since I didn't get fault code 09263, perhaps that tells me it would have been possible.
    As for doing a regen earlier, the car was bought clogged up.
    An ECU update for DPF is shown in the service history at 80k. Car now has 143k (on a 56 plate!)
    Patrick
  4. Re: Cleaning a blocked DPF
    May 2007
    knee deep in clunge
    14 Post(s)
    What soot content do you know see?
    To confirm post your mvb from 68 to 75 and your current ecu part number with the sw version
    Last edited by a8 tech; 03-01-2010 at 11:28 PM. Reason: Sorry i typed the wrong question
  5. Re: Cleaning a blocked DPF
    Jul 2008
    Stafford
    My VCDS is not available at the mo. Will report MVBs etc. when I can.
    The service invoice from Audi for August 08 says "Carried out Worshop Action 23B9" and "Carried out software upgrade for DPF as required".
    Patrick
  6. Re: Cleaning a blocked DPF
    Mar 2007
    Oxfordshire
    Is there any rule to which cars Audi put the DPF on? Mine is a November 2006 TDI 170...I've just ordered a Diesel box btw...
  7. Re: Cleaning a blocked DPF
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by randall977 View Post
    Do nit fit those crappy box's they block dpf for fun no matter what the sellers say they are shi t
  8. Re: Cleaning a blocked DPF
    Jul 2008
    Stafford
    Got VCDS back now. (because of new disaster)
    MVBs you asked about are [with engine not running] :
    68 - 13.5%, 85.16, -20.1%
    69 - 00000000, - , - , 00000000
    70 - 00000000, 0.0s , 0.0, 0.0
    71 - 0/min, 0.0mg, 120BTDC, 0.0KW
    72 -
    73 - 0.8l, 12km, 0h
    74 - 0/min, 8.9C, 1.000, 0.00mg
    75 - 8.9C, 5.3C, 13.5%, 3.5C
    ECU Part No [is this h/w no? which is -] VAG 03G 906 018 AQ
    SW version [is this soft coding which is -] 0000072
    Not sure if any of above is much use with engine not running.
    And that is the new problem... engine cut out today and won't run. something to do with injector electrics?
    Got fault codes:
    004160 - supply voltage A for injectors circuit malfunction P1040 - 006 short to plus intermittent, freq 2, 1856rpm
    and
    008518 - supply voltage for fuel injector grp A : Open circuit P2146 - 009 - open or short to ground intermittent, freq 9
    I plan to somehow check injector wiring loom. Reckon its worth changing regardless. Worried dealers will sell me injectors which may not be required (at £500 a pop so I hear).
    Did about 500miles since DPF fixed. Everything seemed to be fine till today.
    Any feedback very welcome.
    Patrick
  9. Re: Cleaning a blocked DPF
    Mar 2007
    nr Gloucester
    I had the same happen on my 170. The engine cut out and would not start. When they got into the garage, it posted two fault codes can't remember what they were but it needed a new injector. They did change the injector wiring loom aswell as plastic bits were broken off.
    I hope for you it isn't the injector as it was about £500 for the part.
    Ad
    Audi A6 (C7) 3.0 BiTDi Black Edition 2016
  10. Re: Cleaning a blocked DPF
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by patrickhorton View Post
    72 -
    73 - 0.8l, 12km, 0h
    Got fault codes:
    and
    Patrick
    Remove the rocker cover and disconnect the injectors one by one until the engine starts and then replace the defective injector or injectors.
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. XP - Very Slow on Start up...
    By RickT in forum Home Tech Shed
    Last Post: 16-08-2010, 05:56 PM
  3. Diesel Particle Filter
    By prolfe in forum Chat - Anything with wheels
    Last Post: 08-10-2009, 07:08 PM
  4. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  5. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
