Thread: 02/52 passat 130 tdi fuel line fault.
  1. Exclamation 02/52 passat 130 tdi fuel line fault.
    Feb 2006
    Can anyone help me with this. I start my car in the morning, it starts first turn then stops after about say 3 seconds. I then have to turn the engine over until almost the point of a flat battery until it starts. Its just had a new fuel filter and all the connections are tight. I originally thought this was the problem. Has anyone experienced this?
    Jan 2006
    Hi Andy, if this problem just raised its ugly head since you had the new filter fitted then its almost definetly connected. Could well be an air lock of some kind or drawing air from somewhere....could be a dodgy fuel filter(incorrectly fitted?) Try turning the ignition on and off a few times before actually cranking as this will make the low pressure pump build up some pressure before starting...it could be that this pump is playing up..
    6
  1. Fuel Gauge Temporary Fault
    By Sky in forum Audi A4 - Archive Topics
    Last Post: 20-05-2007, 10:20 PM
  2. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
  3. passat locking fault
    By Passat_V6_TDI in forum Chat - Completely Off Topic
    Last Post: 17-11-2006, 07:00 AM
  4. Replies: 0
    Last Post: 29-04-2006, 06:07 PM
  5. Replies: 0
    Last Post: 12-11-2005, 07:27 PM
