Thread: Vr6 idle problem
Results 1 to 10 of 13
  1. Vr6 idle problem
    Aug 2007
    West Yorkshire
    Anyone had problems with vr6's not idling?- mine has been playing up on and off for the last couple of weeks, sometimes it will start and run as normal then other times you have to keep blipping the throttle to keep it from stalling then when driving and the engine has semi warmed up the revs are surging from 2k to 1k at junctions etc.If it is switched of and left for a short while then it seems to start as normal.Is there a cold start sensor or something that could be at fault.
    Also did a fault code scan and it brought up 00268- fault solenoid valve, only info i have found on this relates to auto transmission valve but mine is a manual ! Confussed.
  2. Re: Vr6 idle problem
    134 Post(s)
    2009 Post(s)
    Which year? If it is a 95, I will need the full chassis number or reg number but send this by private message, do not post it.
  3. Re: Vr6 idle problem
    Aug 2007
    West Yorkshire
    Its a 1996 model year
  4. Re: Vr6 idle problem
    134 Post(s)
    2009 Post(s)
    Yes, 00268 is an auto box fault code so the scanner you are using is not providing the correct info.
  5. Re: Vr6 idle problem
    Aug 2007
    West Yorkshire
    Just using the Autel maxiscan VAG405 - I realise it isnt as accurate as probably vag com or similar but hs usually proved to be ok in the past.Had a quick look this afternoon at various possibilities, what effect would the pcv valve have if this was faulty or gummed up?
  6. Re: Vr6 idle problem
    134 Post(s)
    2009 Post(s)
    The PCV valve tends to split open and can cause idle problems. The small pipe to the PVC can also split. You need to know what that code really is, it could be the reason.
  7. Re: Vr6 idle problem
    Aug 2007
    West Yorkshire
    Thanks for the info - Just been looking on some US forums and have seen quite a few post about secondary air injection valve - do UK cars have this or is it just something to do with their strict emmisssion controls?
  8. Re: Vr6 idle problem
    134 Post(s)
    2009 Post(s)
    Yank Golf 3 VR6’s are Mexican built and completely different to ours. No the Golf 3 VR6 for Europe does not have SAI, which is one reason why it is not OBDII like many try to insist it is. OBDII cars have after cat lambda and an engine MIL.
  9. Re: Vr6 idle problem
    Aug 2007
    West Yorkshire
    Often wondered what the differences between OBD1 & 2 where, there seems to be some confusion on various sites insisting that 1996 onwards is OBD2, clearly not the case!.
  10. Re: Vr6 idle problem
    134 Post(s)
    2009 Post(s)
    I think what people think makes a VR6 OBDII is the OBDII style diagnostic plug but then Polo’s had that from 95 and they aren’t OBDII. When people insist the car is OBDII, I ask them (if they have VAG-COM) to click on the Readiness code and see what message comes up. They don’t ever seem to come back when they see the not OBDII compatible message come up.
  1. Please Help Idle and acceleration problem
    By DanFraser in forum Golf MK3 - 1993 - 1999
    Last Post: 11-08-2009, 07:48 AM
  2. Please Help Vr6 atuo gearbox problem
    By Thundertiger in forum Golf MK3 - 1993 - 1999
    Last Post: 14-04-2009, 09:44 PM
  3. Idle Problem A6 1.8t-Newbie Please Be Gentle
    By Saunders1616 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-05-2008, 03:46 PM
  4. 2004 A4 2.0FSi Idle problem..........
    By 4Ringsdrive in forum Archive posts
    Last Post: 21-12-2007, 05:26 PM
  5. Polo idle problem
    By Adam Cooke in forum Polo - Derby - Lupo - Fox
    Last Post: 10-12-2005, 09:08 AM
