Thread: refit door seal on Golf MkV Passenger door
  1. refit door seal on Golf MkV Passenger door
    Dec 2009
    Birmingham, England
    Could someone tell me what addessive VW use to refit the door seals on VW Golf, I believe this is a common problem on Golf mkV? thanks
  2. Re: refit door seal on Golf MkV Passenger door
    133 Post(s)
    1986 Post(s)
    Do you mean the trailing edge seal? I remember getting into a Golf 5 at the Frankfurt launch on launch day as the stand opened and on the first Golf 5 I tried, the trailing edge seal fell off.
  3. Re: refit door seal on Golf MkV Passenger door
    Dec 2009
    Birmingham, England
    Yes, this seal I believe is a common problem. Thanks
  4. Re: refit door seal on Golf MkV Passenger door
    Jan 2010
    Nottingham
    VW use a self adhesive tape to hold the seals on MK5 doors. The tape is appiled to the seal off the car and welded to the rubber seal with an Ultra vilot heat. The tape backing is then removed when the seal is applied to the doors and put in the door with a robot. This is where the problem comes in that it does not allow enough seal into the convex parts of the door and hence streching in these areas. Ultimatly bad design and fitment. this can be improved by hand aplication laying the seal on with no strech. Best bet is to remove all tape and use Evo stick contact adhesive as the main dealers do.
  5. Re: refit door seal on Golf MkV Passenger door
    York, UK
    I refixed the seal along the bottom of one of my Mk V's doors with your basic household Epoxy Glue such as Araldite. Worked fine.
    Remember to make sure both surfaces are clean and dry. Once applied, just close the door and leave for a while to allow it to adhere properly.
    Stuart
    http://www.stuartdalby.co.uk/vwgolfmk5
  1. new golf estate
    By jcb in forum Golf MK6 - 2009 - 2013
    Last Post: 20-11-2009, 12:36 PM
  2. mk 4 golf passenger side door wont open
    By jhueym in forum Golf MK4 - 1999 - 2004
    Last Post: 04-11-2009, 06:37 PM
  3. Golf Mark V passenger door not opening
    By Kippers_Cracks in forum VCDS - General Questions
    Last Post: 26-10-2009, 03:20 PM
  4. Bora Central Locking Probs!!
    By DiverDave in forum Bora - 1998 - 2005
    Last Post: 23-09-2006, 09:37 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
