Thread: Expansion Tank
Results 1 to 10 of 17
  1. Expansion Tank
    Aberdeen
    Hi all,
    My expansion tank decided to develop a hole on Sunday morning and it needs replacing. I've got the 2.6 V6 and I've been looking on ebay and found one for a 1.8. The picture looks the same as the one in my car. Are they the same or do I need a different one? Also, the local breakers has diesel ones....are they the same because if they are, they're local and I can get it sorted sooner.
    Thanks in advance
  2. Re: Expansion Tank
    Newcastle upon Tyne, England.
    I can post a pic of mine if you like? It's on a 97 1.9 TDi 110.
  3. Re: Expansion Tank
    Aberdeen
    yes please
  4. Re: Expansion Tank
    Jul 2008
    stoke on trent
    the level sender connection was changed aound 97 there not inter-changeable so you need to check and match the plug
    other than that there the same for petrol/tdi's except for v6 tdi which has a slightly different hose connection location
    also the b6 one can be made to fit later models
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  5. Re: Expansion Tank
    Aberdeen
    oh ok. so if i get one thats pre 97 then it should fit? I'll take mine to the breakers and compare it
  6. Re: Expansion Tank
    These are the parts fitted to mine; the expansion tank and the coolant level indicator plug connected to the bottom of the tank.
  7. Re: Expansion Tank
    Aberdeen
    ok, ive just had a good look in bad light and i can see places for 3 hoses and 1 sensor. all but 1 hose is attached. the one that isnt is the one underneath where the sensor is. and i cant seem to see the hose anywhere at all got to try and find a torch and have a proper look. atleast its not a hole which i guess is a good thing lol
  8. Re: Expansion Tank
    Jul 2008
    stoke on trent
    theres only 2 hoses, hole underneath is for when cap releases pressure
    90 eunos roadster
  9. Re: Expansion Tank
    Oct 2009
    Cleveland, OH
    They have different part numbers which means that there is a change in someway that prevents them from being cross compatible. However, that might all be in the cap, so if you can get a look with some light, I'd start there.
    :: www.ECStuning.com :: IS NOW OPEN TILL MIDNIGHT EST FOR PHONE ORDERS!!
    Phone: 1.800.924.5172 - 8:30 am to 12:00 am | Email: Pete@ecstuning.com | Questions? PM us for a quick response!
  10. Re: Expansion Tank
    Aberdeen
    um....so the hole underneath would need some sort of valve or bung connected to the cap? i couldnt see anything like that :S
  1. temp problem
    By rampagey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 02:11 PM
  2. Golf expansion tank with sensor?
    By Strandl5 in forum Golf MK3 - 1993 - 1999
    Last Post: 23-04-2008, 09:38 PM
  3. Mucky Expansion Tank
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-04-2008, 11:23 PM
  4. Oil in Expansion Tank - PD150
    By KashBash in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2008, 06:42 PM
  5. Expansion Tank 1.8 20v.2000 Passat
    By paul vivian in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-01-2008, 09:43 PM
