Thread: Polo 1043 stalling when V. cold
  1. Unhappy Polo 1043 stalling when V. cold
    Feb 2006
    Wimborne, Dorset
    Occasionally, when the weather is icy, my 1990(H) 1043 Polo cuts out whenever the clutch is depressed, but only while the engine is well below operating temp. The prob disappears as soon as the temp gauge needle starts to rise. This model (carb. fed) has a 'two-way valve' which applies a vacuum feed to the carb (Pierburg 1B3) when cold, to increase the idle speed. The valve is working but whatever controls it doesn't seem to do anything to operate it. I think this is the problem because I've checked everything else I can think of, unless... Anyway, does anyone know what controls this valve (attached to bulkhead to right of carb, with two vacuum pipes attached, one from inlet manifold, the other to the carb base, left hand side). The carb is otherwise faultless (now I've replaced the pull-down unit) which is pretty amazing considering their reputation!
    Cheers.
  2. Re: Polo 1043 stalling when V. cold
    I have similar trouble with my 86 1043. Mechanic says auto choke is shot and I am now looking for a manual choke carb or manual choke conversion kit
  1. Polo Heater cold at tick over
    By GrahamS in forum VCDS - General Questions
    Last Post: 25-08-2011, 08:21 PM
  2. stalling passat
    By tony2311 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-05-2010, 01:07 AM
  3. Water temp warning light flashing from cold - 98 Polo 1.4 auto
    By Scudetto in forum Polo - Derby - Lupo - Fox
    Last Post: 05-04-2009, 10:23 PM
  4. Polo 1.4 60bhp (akk) - bad cold idle
    By achundee in forum Polo - Derby - Lupo - Fox
    Last Post: 15-03-2007, 08:57 AM
  5. Cold starting probs on Polo Diesel
    By billyboy in forum Polo - Derby - Lupo - Fox
    Last Post: 29-08-2006, 10:34 AM
