Thread: constant hot blowing air con
  1. constant hot blowing air con
    Aug 2008
    Hi everyone i have a 54 plate A4 cab 1.8t quattro, last week the pasager side air con is constantly blowing hot air regardless of what tempreture i set it on if i turn it down to LO is still blows hot the drivers side is ok
    has anyone had this before and if so who did you use to repair it how much? in in the leeds area
  2. Re: constant hot blowing air con
    Dec 2007
    try the search its been covered loads of times all info is there if you take the time to search
  3. Thumbs up Re: constant hot blowing air con
    Aug 2008
    Hi thaks for the advice i don't visist the forum that much so didn't know how to search anyway i did what you said and found some simila
    faults and how to get to the servos after removing the clove box (2mins)
    i adjusted the heat on the passanger side all was ok levers moving etc so i set it to low and it went cold so don't realy know what
    iv'e done but it works fine now maybe the carpet at the back of clove box
    was fouling the servos??
    but anyway thanks
  4. Re: constant hot blowing air con
    Dec 2007
    not a problem i knew ud find it easy enough you may get the same problem again sometimes they stick sometimes you get them unstuck
    bit more info for u as your new the rep button is for giveing rep to ppl that help you out
  1. Air Con Playing Up?
    By stu22uk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-03-2011, 09:48 AM
  2. ECON Light - Air Con
    By biker_billy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-08-2009, 07:54 PM
  3. Golf Air Con Not Cooling
    By colinmchardy in forum Golf MK4 - 1999 - 2004
    Last Post: 28-06-2009, 12:51 AM
  4. Heater only blowing hot air on passenger side
    By stuartt0712 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2009, 08:16 PM
  5. Air con making rear footwell wet?
    By Dfardon in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-03-2008, 10:52 AM
