Thread: Golf mk3 cab drivers side window not working.
  1. Thumbs up Golf mk3 cab drivers side window not working.
    Oct 2009
    london
    Hi guys,
    I just bought Golf Mk3 Cab on 1998 plate, The drivers side window is just dead there is no power its not doing anything, I've looked at the cable in the door hinges it all seems fine the rest of the windows are working fine too, Any help would be great!!!!
  2. Re: Golf mk3 cab drivers side window not working.
    does it work from the drivers side switch. on my other half car, her pass side switch doesnt work, but it does from the other switch mounted on the driver door
  3. Thumbs up Re: Golf mk3 cab drivers side window not working.
    Oct 2009
    london
    Quote Originally Posted by g40jon View Post
    thankx for ur reply, will try that soon as.....
  4. Re: Golf mk3 cab drivers side window not working.
    Dec 2009
    Burton, England
    If that suggestion is a no go mate, suggest direct feed from a battery to the window motor itself. If that doesn't give a result then you'll know what the problem is. If you own or can get hold of a spare battery (or even off your own if you have sufficiently long cables to test from it) then just clip on (or tape as it's not a long job) and away you go.
    Without sounding like a daft git, have you taken the door cards off before?! :lol: They can be simple or a pain in the ar*e depending on how lucky you are... kinda pot luck depending on previous owners and what they've been up to with them!
    Shout back fella and let's see if we can get you all powered up again!
    Happy New Year!
  1. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  2. Drivers side window stuck open
    By unknowngman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-01-2010, 12:57 PM
  3. Please Help Mk3 golf cabrio window issues...
    By luke_trend in forum Golf MK3 - 1993 - 1999
    Last Post: 23-11-2009, 10:33 PM
  4. HEADLIGHT PROBLEMS!! - one works, one does not.. HID's
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2009, 12:54 PM
  5. Driver's side window scratched
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2007, 04:25 PM
