Thread: Light Switch
Results 1 to 10 of 16
  1. Light Switch
    Jan 2009
    I might be being a little thick, but how do I remove the headlight switch from a 54 plate avant ? Mine is bust, but don't want to wreck the dash removing it !
    Also, Audi tell me the part i out of stock until the end of January - can anyone recommend anywhere I might get one - mine is the one with manual operation only.
    Rich
  2. Re: Light Switch
    Nov 2008
    N/A
    In the MkIV Golf, you pushed it in a bit, turned it to the sidelight position and then pulled to get it out. I imagine it's the same for the A4.
  3. Re: Light Switch
    Oct 2009
    Derby, England
    The switch is retained by a pair of spring loaded bayonett's on the side of the barrell which engage with cut-outs in the plastic moulding. With the lights in the off position, push the control inwards and rotate about 10 degrees clockwise. That will retract the bayonett's, then simply pull the switch out and presto!
  4. Re: Light Switch
    Dec 2007
    id call audi back i cant see it takeing till the end of jan if i order and parts are out of stock its usaly 24 hour or 3 days at the most
  5. Re: Light Switch
    Jul 2008
    Bristol
    How much are Audi charging for a Light Switch? Is there any other places where I can purchase one?
  6. Re: Light Switch
    Dec 2007
    audi or ebay if ebay make sure you get the same part number as yours
  7. Re: Light Switch
    Jul 2008
    Bristol
    Quote Originally Posted by bez101 View Post
    I have looked on ebay, but they are going for £30 - £40 Any ideas on how much will Audi charge? Thanks for informing me about the part number
  8. Re: Light Switch
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by Zeb View Post
    The light switch assembly with the independant front / back fog switch (which I think the A4 requires) cost me about £36 (for my Mk.4 golf) several years ago, so £30 - £40 sounds about right!
    Do all the illumination bulbs for yours still work? If so, I'd consider buying it off you! (although mine works fine, only half of the facia illuminates!)
    Al.
    [ My Cars: 2011 Caravelle SE TDI (140) LWB | 2015 L200 Barbarian 2.4 DI-D | 2015 Mini Cooper SD ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  9. Re: Light Switch
    Mar 2009
    Brighton
    I needed to replace mine a few months back as couple of the illumination LEDs had gone (not replaceable apparently).
    From memory, cost me about £65 from Audi.
    Embisix
    Current: 2010 A4 2.0TDI Quattro S line Executive Saloon (Sepang Blue Pearl)
    Previous: 2004 A4 Avant 1.9 TDI Quattro Sport (Atlas Grey)
    Previous: A string of (mainly) DOHC VTEC flavoured Hondas
  10. Re: Light Switch
    Southern County Softy
    20 Post(s)
    My switch cost £70 from Audi, but it has autolights and coming home function....
    A4 2.5 tdi QS (mapped)
  1. "How to" Repair cam of O2A 945 413 reverse switch
    By imortalmonkey in forum Volkswagen
    Last Post: 03-05-2009, 09:30 AM
  2. Please Help Green brake light switch
    By JayWorm in forum Golf MK4 - 1999 - 2004
    Last Post: 02-05-2009, 04:45 PM
  3. brake light switch
    By davey670 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2009, 08:26 AM
  4. Sat Nav Retro Fit Fog Light Switch Problem!!!!
    By Kevin Hay in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-03-2009, 08:15 PM
  5. hazard warning light switch
    By tricolourdog in forum Bora - 1998 - 2005
    Last Post: 25-01-2008, 06:28 AM
