Thread: Welding Tie Downs in rear.
  1. Welding Tie Downs in rear.
    scoobystu Guest
    Does the transporter come with tie down points as standard. The one I have just bought has been ply-lined so it's hard to see if there are tie-down points under it without taking it out.
    If I were to get some welded in the back what do I need to disconnect with respect to electronics in the van? Battery, ECU?
    Stu
  2. Re: Welding Tie Downs in rear.
    Mar 2007
    fife.scotland
    ive got 6 in mine and there bolted any welding disconnect the battery earth first then earth on last
  3. Re: Welding Tie Downs in rear.
    scoobystu Guest
    Thanks again dov, I did a bit of investigating and found the 6 holes for tie-downs and ordered some up about a fortnight ago. The holes were fairly corroded but brute force and ignorance sorted them out.
    Stu
  1. Bora Welding Marks on Boot Floor - Normal??
    By Nickyboy in forum Bora - 1998 - 2005
    Last Post: 07-03-2007, 08:52 PM
  2. Bora Welding Marks on Boot Floor
    Last Post: 05-03-2007, 08:21 PM
