Thread: Headlight Problem
  1. Headlight Problem
    May 2008
    Hey folks!
    Bit of a headlight problem. Symptoms:-
    Both dipped headlights dont work.
    No voltage at the lamp holder.
    RH Dipped, LH Dipped, and Dipped headlight control fuses are fine.
    Both Main beam headlights work.
    Both Side lights work.
    I think its pointing towards a relay.
    Where are the headlight relays? (pulling all the relays behind the drivers side facia doesnt seem to kill the main beam lights)
    Haynes manual was next to no help.
    Any suggestions much appreciated!
  2. Re: Headlight Problem
    Mar 2009
    Did you have any luck fixing this? I've got a similar problem on my A4, but only with the RH dip. Changed the bulb, swapped fuses, nothing.
  3. Re: Headlight Problem
    Mar 2010
    Hereford, UK
  1. overheating & burning headlight switch - recurring fault
    By rdlb in forum Golf MK3 - 1993 - 1999
    Last Post: 07-03-2008, 01:17 PM
  2. Mark 4 Golf Starting problem.
    By Oztrexx in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2008, 01:08 AM
  3. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  4. Headlight Dip problem
    By northness in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-10-2006, 08:09 AM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
