Thread: DPF or no DPF?
Results 1 to 9 of 9
  1. DPF or no DPF?
    Jul 2007
    Matlock
    just rang my nearest main dealer who is 14 miles from home to ask if my car has a DPF.
    After taking my vehicle registration number and confirming the model, they rang me back to tell me that they did not know and that i would have to take the car to them so that "we can shine a torch down the back of the engine to see if it has one or not".
    Does this type of answer really fill you with confidence that when you have work done on your car at main dealers they actually know what they are doing?
  2. Re: DPF or no DPF?
    Mar 2009
    Which model do you have?
  3. Thumbs up Re: DPF or no DPF?
    Jul 2007
    Matlock
    it is a JETTA 2.0 TDI SPORT 140 registered in September 2008.
  4. Re: DPF or no DPF?
    May 2009
    Basingstoke, UK
    Quote Originally Posted by SMEG View Post
    While not completely 100% as far as I am aware the 140 doesn't have the DPF but the 170 does.
  5. Re: DPF or no DPF?
    Mar 2009
    CSanchez is correct in that the 170PS models came with DPF as standard, however, you could order the DPF as an option on the 140.
    More likely than not you won't have one. Look for this symbol (or similar) on the dash when you turn the ignition on. It should light and then extinguish if a DPF is fitted
  6. Re: DPF or no DPF?
    Jul 2007
    Matlock
    Hi guys,
    Thank you both for your replies.I have checked for this symbol on my dash and it was not visible which if you are correct means my car is not fitted with a DPF.
  7. Re: DPF or no DPF?
    DURHAM-UK
    Hi, bit of a late comer to this one ha ha.
    Im almost certain that the non DPF cars have hidden exhaust tail pipes and the DPF cars have them sticking straight out the back of the valance.
    Im sure this is so the exhaust residues are shot straight down to the ground were as the DPF cars produce no visible residues coz thats what the DPF is there for.
    auds2
  8. Re: DPF or no DPF?
    Up North
    You can find out exactly what you have by using the options code decoder http://igorweb.org/equidec/Default.aspx.
    Get the codes from the inside page of your service book or else off the sticker in the spare wheel well. Put them into the decoder and it will tell you everything you've got.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  9. Re: DPF or no DPF?
    Jul 2007
    Matlock
    Thank's Teflon.
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. XP - Very Slow on Start up...
    By RickT in forum Home Tech Shed
    Last Post: 16-08-2010, 05:56 PM
  3. Diesel Particle Filter
    By prolfe in forum Chat - Anything with wheels
    Last Post: 08-10-2009, 07:08 PM
  4. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  5. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
