Thread: Audi Cabriolet 1994 Power Window Problems
  1. Audi Cabriolet 1994 Power Window Problems
    May 2007
    Hi all. I have a 1994 Cab.The front electric windows (passenger / driver) have stopped working. However the center switch still works so i can put all windows down/up with that button. I have checked to see if i have power to the door and i do not. Unfortunately to try and follow the wires back to the point of power loss is impossible without a wiring diagram. I have looked in the fuse / relay box (in the engine bay) but there are no fuses/relays relating to the windows. Should I be looking anywhere else. Any suggestions?
    Thanks in advance for any help.
    Nov 2006
    I would really like to know the answers to this question too if anyone can help. I had the same sysmptom (but driver door only) a few weeks back after the car was parked out in the hot sun.
    B.
  3. Re: Audi Cabriolet 1994 Power Window Problems
    Jul 2008
    Did either of you get answers to this?
    I have had the same problem - just driven the car to Switzerland and back (from UK) and car was in sunshine for a while as well.
    No power to either door controls (except mirrors) and centre console works all windows bar drivers. When I drop the hood (98 manual version) all windows auto lower except drivers.
    Only way I can get drivers to lower is to use combo of centre console down and hold the other 3 windows up on the drivers door panel.
    How did you get yours fixed? Any ideas or tips?
  4. Re: Audi Cabriolet 1994 Power Window Problems
    Nov 2006
    No... didn't find the cause of the problem... but it only happened twice or three times so I didn't need to worry too much about it.
    Did find a solution though! :-) ... A4 Cab 3.0L V6
  1. Cabriolet Rear Window
    By Timja in forum 80 - 90
    Last Post: 25-03-2010, 11:44 PM
  2. Audi cabriolet 1.8 bad flat spots in power
    By 4rings in forum 80 - 90
    Last Post: 26-06-2007, 03:24 PM
  3. Electric window puzzle - 1994 cabriolet
    By ping_zero in forum 80 - 90
    Last Post: 27-11-2006, 12:04 AM
  4. Audi Convertible - 1994 - Elec Window Prob!
    By Will Giles in forum Archive posts
    Last Post: 30-10-2006, 05:14 PM
  5. Passat power window and other problems
    By Schorly in forum Archive posts
    Last Post: 03-10-2006, 01:23 PM
