Thread: Audi Concert Radio CD
Results 1 to 8 of 8
  1. Audi Concert Radio CD
    graham warner Guest
    Hi everyone,
    I have an Audi A3 TDi with a Concert Cd Radio. I am having problems with AM reception. It has a roof aerial and FM reception is fine. Has anyone got any suggestions Thanks
  2. Unhappy
    Bracknell, Berkshire
    Graham,
    I have just had my Concert CD/Radio replaced with an after market unit. I am having problems with my radio reception with the new Alpine unit.
    If you like, I can lend you my old Concert radio for testing if you don't live too far away.
    PM if you are interested.
    Regards,
    Teg
    Whoever Wins Is The Hero
    graham warner Guest
    Teg,
    Thanks for your offer but I have 2 radio cd players and they both do the same. Do you get the same problem with your new Alpine unit. Have you got a roof aerial. Thanks again,
    Graham
    I had no reception problems with the Concert unit. FM was clear and AM was very good. With Alpine it is all just a hiss regardless of band. Even manually tunning into KISS 100 gives a weak signal (just about hear the music in the background) with major interference on top. No roof aerial, must be part of rear window or inside roof?
    Any suggestions would be greatly received.
    Regards,
    Teg
    Mar 2007
    Near Whitby, N.Yorks
    Hi guy's, when I got my A3 it had the concert radio in but it had been butchered out of the dash and damaged so didn't work. I replaced it with a Pioneer cd/radio that I had fitted in my Golf. It played ok on cd but the radio had no reception at all, put it back in the Golf and hey presto on there was the radio clear as a bell.
    Any way what I discovered was that the A3 has a powered aerial with a switched feed off the back of the Concert cd/radio head unit, without that no reception.
    If your lucky enough to have the wiring sticker still on the back of the Concert it shows the connection there.
    I hope this helps a little
    Cheers Tom
    I still need help with this. The aerial amplifier has been powered up with 12volt feed but has made hardly any difference.
    Anyone got any other suggestions? Replace with a new aerial all together?
    If anyone can help I would be very grateful.
    Regards,
    Teg
    May 2007
    Bath, Wilts
    Hi TEG,
    Similar problem. Found broken socket (feed to radio) on the diversity board located rear near-side (LHS) rear wheel arch (in boot) above bass unit - it has 4-sockets & a small power plug on it.
    It helps fading on AM & UHF. I now have v poor FM and no AM.
    If faulty (like mine) it'll cost £100 for a new one !!
    Haven't found a 2nd hand one yet, but am looking.
    I would suggest you have a look at yours !!
    Trev McM
    Thanks for your response. I will get this checked out but when I had the concert radio fitted, reception was crystal clear.
    With the new Alpine, generally it is very poor unless I am in a built up area and then I get quite moderate reception but not as good as with the concert.
    Should I look to get a new aeral fitted? Either hidden or on top of the car?
    Regards,
    Teg
  1. Radio Options to replace Concert?
    By samd in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-06-2007, 10:33 PM
  2. Audi Concert Radio "SAFE" message
    By bob07 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-04-2007, 10:38 AM
  3. Concert radio problem.
    By Barnz in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-03-2007, 08:21 PM
  4. Concert Radio - can code be disabled?
    By gary_m in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-02-2007, 09:47 PM
  5. Alternative to concert radio cassette
    By Mike Allen in forum Audi A4 - Archive Topics
    Last Post: 04-12-2006, 02:19 PM
