Thread: A4 power loss HELP HELP HELP
  1. A4 power loss HELP HELP HELP
    Oct 2007
    i have a 04 a4 tdi 100bhp se was drivin it last week and was doing about 110 on the motorway then has to slow down because of a van then went go give her the power and no power at all.
    stopped and it was going on three pots not 4.
    the engine light was on and the abs.
    drove it on home turning it of and then back on again just to get power did not drive it the next day and the day after that it was fine with no lights on at all.
    it has happened again tonight can anyone help
  2. Re: A4 power loss HELP HELP HELP
    2024 Post(s)
    You have logged a fault code which could be any one of dozens. The ECU memory will hold the codes so if you want to know what it was you will need a code read. The code will probably be 17965 over boost but the misfire is odd and may come up as a cylinder misfire and probably be number one but as I said, you need a code read.
  3. Re: A4 power loss HELP HELP HELP
    Oct 2007
    have vag com and it came up as cylinder one misfire. no word of over boost.
    have been told that it might be injetcor wiring loom.
  4. Re: A4 power loss HELP HELP HELP
    2024 Post(s)
    Yes do the injector wiring loom first, that should cure it.
  5. Re: A4 power loss HELP HELP HELP
    Oct 2007
    i will give it ago
  1. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  2. Audi A4 TDI loss in power once engine warms up
    By EmmettC in forum Audi A4 - Archive Topics
    Last Post: 29-11-2007, 08:43 AM
  3. A4 1.9TDI (96) high Mileage - Loss of Power
    By Dreamweaver in forum Audi A4 - Archive Topics
    Last Post: 02-08-2007, 02:02 AM
  4. Audi A4 tdi loss of power
    By siddlem in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2007, 09:07 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
