Thread: Very dim dip headlights
Results 1 to 10 of 12
  1. Very dim dip headlights
    Dec 2009
    Malmesbury, Wilts
    Hello
    I have had many VW' and Audi's and generally are able to solve most problems but this has me stumped!
    I have just acquired a 2000 (W) A4 B5 TDI Estate and I'm really happy with it. However I notice that the headlights are really dim when dipped. Not too bad on full beam but then again not as good as my old VW Caddy pick up!
    I have replaced all the standard H7 55w bulbs with Xenon 100w bulbs and although a little brighter on main beam the dip is still really poor.
    Any ideas?
    Kind regards
    Jon
  2. Re: Very dim dip headlights
    Jun 2008
    I am guessing you have a face lift model and it is normal the dipped beam is very weak. I upgraded to a HID kit which has solved the problem. I think the projector lense for the dipped beam on the face lift headlights is too thick for standard bulbs and reduces the brightness.
  3. Re: Very dim dip headlights
    Dec 2009
    Basingstoke, UK
    I would go the same route as martin above. If you have projector lenses you'll be fine with HID's, 6000k are probably the best for on road use.
    I've been running them on my BMW for years, they're cheap(ish) and easy to fit and will be the first thing i fit when i finally buy the new car.
    Only problem with HID's is that once you've used them you will hate driving without them.
  4. Re: Very dim dip headlights
    Dec 2009
    Malmesbury, Wilts
    Quote Originally Posted by martinA4passat View Post
    Indeed it is a facelift.
    Thanks for the advice.
    Looks like I had better look into getting four HID kits (dip and main) any ideas where is the best place to get them at a reasonable price? What with Xmas on the way things are a little tight.
  5. Re: Very dim dip headlights
    Jun 2008
    HID's direct were pretty reasonable paid around £80 with delivery for a set of 2, off ebay. Don't bother with the £25 to £50 kits as I wouldn't want to be stranded out somewhere if they fail and I have heard of some kits not working when fitted and you have to go through the hastle of replacing.
    I didn't bother changing the main beam as the dipped beam stays on when you put on the main beam so you still get the extra brightness.
  6. Re: Very dim dip headlights
    Dec 2009
    Basingstoke, UK
    Here's another vote for HID direct. The service Martin provided me was spot on
  7. Re: Very dim dip headlights
    Dec 2009
    Malmesbury, Wilts
    Cheers for the advice guys.
    I have just noted that HID Direct sell on ebay (slightly cheaper than the website) so I will get a set from there.
    http://cgi.ebay.co.uk/50w-HID-Conver...item334d72c892
    Looks like the 4300k is the brightest so might get them, or as you say the 6000k. Is there any advantage to them having a bluer look?
    Jon
  1. passat tdi 4 motion 2004 - you can adjust dip headlights for eu driving...
    By stratton in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-05-2009, 03:33 PM
  2. Replies: 2
    Last Post: 02-01-2008, 10:13 AM
  3. Dip beam headlights not working
    By deamie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-11-2007, 02:23 PM
  4. How To Disable Dim Dip
    By noppygolf in forum Golf MK3 - 1993 - 1999
    Last Post: 13-09-2007, 12:43 PM
  5. Headlights went out on A4
    By former dallas eagle in forum Chat - Anything with wheels
    Last Post: 11-03-2007, 06:09 PM
