Thread: Audi A6 Window Window Lisfts
  1. Audi A6 Window Window Lisfts
    Aug 2009
    Lancaster
    I have just put in a window cable and regulator kit on my 98 A6 from Ebay.
    The kit looked good and I fitted it today - The only problem I have had is that the holes for the regulator bracket seemed a fraction different from the window frame, I carefully took around 1mil off the holes on the frames to make the new bolts and rivets fit correctly.
    I refitted the window glass and problem two the plastic inserts to hold the glass in were a liitle tight but with a bit of effort they drove in.
    Problem three I reffitted the window frame with glass and motor rebolted in and low and behold the window begrudgingly lifted up half way and then wound it self back down again with a squeeling sound.
    I know the obvious the motor but anyone else have experience of these replacement window regulator kits and any ideas ?
  2. Re: Audi A6 Window Window Lisfts
    Southern County Softy
    20 Post(s)
    Pinch protection...if the motor senses the window not raising correctly it will go down.
    You could try lubricating the runners.
    A4 2.5 tdi QS (mapped)
  1. All-new audi a8 travels light to miami debut
    Last Post: 02-12-2009, 08:58 PM
  2. Replies: 0
    Last Post: 29-06-2006, 08:27 PM
  3. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
  4. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
