Thread: Missing lights in display?
  1. Missing lights in display?
    Ruby Guest
    Hallo,
    Have just bought a 1999 A6 2.4SE Auto saloon, what a lovely bit of kit!
    One little thing I have noticed is there are a few lines of red lights missing from the display. I know this is not a big problem, but would this be easy to fix or would the display need to be replaced at probably vast expense?
    Thanks for any advice,
    Ruby
    Feb 2006
    replacing the display would be expensive...suggestion just try disconnecting the battery for 5 minutes and reconnecting as sometimes works. becarefull about losing ur radio code etc
    Ruby Guest
    Thanks shooey88, I'll give that a try,
    Ruby
  4. Re: Missing lights in display?
    Mar 2007
    Hi Ruby, i had a similar problem with the display on my passat, it only happened when the car had been standing for a while, i had only been using it at weekends for about three months when i fist noticed, however i have discovered that the lines dissapear with use. As sson as i began to drive the car regularly again they dissapeared. I can only contribute this to some condensation or corrosion appearing on the contacts and stopping the display from working until the car warms up properly or current burns the corrosion off the contacts.
    Hope that helps, good luck!
  5. Re: Missing lights in display?
    Ruby Guest
    Thanks maliceinwonderland,
    The missing lines just seem to come and go, they seem to have a mind of their own!
    Ruby
  6. Re: Missing lights in display?
    May 2007
    This display missing lines is a known Audi issue.
    removing battery will have no effect. It is the contact between the displacy and the board that has connection issues over time. You will notice that the quality of the display changes as the temperature changes.
    fixing is difficult, many people have tried with varying levels of success. Only sure way is replacement parts from Audi, which is expensive to say the least.
  1. Missing Horn
    By Alan Griggs in forum Chat - Anything with wheels
    Last Post: 20-02-2008, 02:27 PM
  2. Missing pipe?
    By Pegleg in forum 80 - 90
    Last Post: 05-04-2007, 09:49 PM
  3. Looking for some missing threads?
    By Sam in forum Chat - Completely Off Topic
    Last Post: 16-03-2007, 04:47 PM
  4. Have I got a bit missing?
    By renedrag in forum Audi A4 - Archive Topics
    Last Post: 11-03-2007, 05:31 PM
  5. missing
    By rsgranduca in forum Touran - Sharan - Caravelle
    Last Post: 07-03-2007, 12:38 AM
